Worth upgrading i7 5820K to i7 5960X?
Caporegime
1 Jun 2006
Notts
depends on the game and the gpu. battlefield and pubg and witcher there is massive differences.thing is 99 percent of these stupid reviewers use single player games.
27 Jan 2009
I would imagine would some good reason? Hard to test consistently over multiple cycles in a multi player environment?
Of course this doesn't stop performance in multiplayer scenarios being relevant to the consumer.
10 Jul 2013
Space
Was going to point out game variation it’s something that doesn’t get mentioned enough with these reviews. I understand multiplayer is has its own set of issues as a Youtuber I remember how Crysis was the go to game to show system capabilities not that long ago
OP
20 Nov 2009
Haarby, DENMARK
Had forgotten to set my fans to run after the CPU temperatures after the BIOS update. Setting them to CPU temperature target again took around 3~5°c off per core.
This after 2½ hours OCCT.
14 Oct 2017
If you were to play @ 1440p/4k the difference in fps between the 2600k and 8700k would be even less. Strictly speaking, games are still GPU bound at higher resolutions and a decent quad core past sandy bridge isnt warranted an upgrade.
OP
20 Nov 2009
Haarby, DENMARK
As a final touch to it all. While I in my own rig got an i7 6900k, I managed to grab a i7 5960X also on ebay, which will replace my wife's i7 5820K. I can't wait to compare the 5960X vs 6900K.
