I am hoping for this as well, we had few Bios revision but the QVL for RAM is from release day.Not expecting anything at all in the performance department, just hopefully better RAM compatibility so expensive Samsung-B dies aren't necessary any more.
Its the spec sheet for the HP ENVY x360 15-bq101na,which appears to be the first Raven Ridge laptop.
How much performance loss should be expected with that single-channel memory?
It supposedly includes substantial changes to RAM settings too. Whether that'll actually improve compatibility or performance though remains to be seen.What's there to be hyped about? All the new AGESA is going to do is add support for APUs. We haven't had a performance improvement since AGESA 1004.
It might only have one populated slot as the previous Bristol Ridge version had two slots.
This means that one populated or physical slot will be enough to work like in dual-channel mode?
I mean is the available memory bandwidth the same?![]()
No it means they probably have only used one of the two slots to save money - so you need to add another DIMM to enable dual channel mode.
However,the DDR4 memory controller on Bristol Ridge is poor,so even in single channel mode Ryzen should have more memory bandwidth in single channel mode than Bristol Ridge in dual channel mode!
2 issues immediately pop up.
First, how will you get a second identical module;
Second, even if so and bandwidth is improved, the single-channel mode in general limits the GPU and CPU performance by quite a significant margin.
I don't see any sense in them doing so![]()
Potential improvements in how the RAM works. Though mines reasonably tight any improvements in attainable frequency would be welcome.![]()
Its the difficulty in obtaining rated speeds and/or overclocks for your average joe that is the main issue, imo.
Took me a while trawling forums for info to get mine running well! (Not to mention buying another set of ram and another motherboard)
People jumped on the update yesterday, all my OW friend list was empty.It looks like the Win10 Creators update has increased performance in GTAV by around 5% it seems:
https://www.reddit.com/r/Amd/commen...utm_medium=hot&utm_source=reddit&utm_name=Amd
I wonder if it helps other applications too??
