That's a first - a computer building cat!!
What is funny is that she would probably have a better crack at it than I did last night.
Doesn't look amused at all.What is funny is that she would probably have a better crack at it than I did last night.![]()
I used to have this with an older card.Any 56 owners getting the atikmdag.sys error message at all? A build I did for a customer is giving this error message a lot (games crashing). I'm thinking it's the GPU and not the rest of his system. Anyone?
If you get the custom loop Vince, i'll buy that eiswolf from you, they are still not in stockWhat is funny is that she would probably have a better crack at it than I did last night.![]()
It's thinking damn this water cooler is ugly, i would have used a water block... But then again my static discharge is too highDoesn't look amused at all.
I think he could wait until you would unpack everything and he could adopt the box for his needs.LOL.
Its a cat,so she must be thinking why all this money on computer bits when that would be a load of fish for me?? Hu-man why do you waste your money??
My advice is. Go into safe mode for windows, use DDU driver uninstaller.
Download ATIflash and flash the cards bios to a different 56 bios (to be extra safe, after restart find the original manufacturers bios and then reflash that)
Worked on my 7970, hope it works for your friend
I gave up after 2 tries, 2nd time i checked to make sure it had contact with the core. Just in Windows temps fluctuated a lot, doing a quick test twice was enough to kill the GPU. So don't expect auto shutdown to save your card if it ever goes above the temp limit even for just a short period.Nope nope nope and nope... something seriously wrong with this cooler or me. I have refit it like 10 times and its no good. Hotspot temps under any load shooting for the moon at over 100 degrees, the pump is giving readings but sounds like there is a load of air stuck in it.
Air seems to be an issue with these things, if it's not that then I'm not sure.. We shouldn't have to buy any reservoir to fiddle around getting air out, it's supposed to be a cooler that you just connect 2 hoses and be done with it.
Seems like it's more trouble than the worth of it tbh, i might just end up getting a decent air cooled card next time. Never had an issue when i used to water cool the CPU, but the GPU has made me feel like not wanting to do it again.
Sounds like it's just a crap cooler, even with having to template and re-drill the G10 bracket and base plate the mod only took a couple hours end to end for me. I'm a mechanic by trade but still, I was being careful and drinking beer LOL.
Don't blame yourself, a product like that ought to be a no brainer.
My basket at Overclockers UK:
- 8 x EK Water Blocks EK-ACF Fitting 13/19mm - White= £5.99
- 1 x Mayhems Ultra Clear Watercooling Tubing (12 - 34) 19/13mm - 1m= £2.99
- 1 x EK Water Blocks EK-CryoFuel Blood Red Concentrate 100 ml= £5.95
Total: £66.76
(includes shipping: £9.90)
easiest option would be soft tubing, then you just need some distilled water from a local hardware store. Depending on the spacing in the case you may need some angled fittings (EK 45 or 90) and you may need a mount for the pump unless you have holes in the case that accept the mountings it has. I got a EK fan mount for my D5 res/pump combo.
Probably need more than 1 meter of tubing, i forgot to change it.
I feel your pain, I often look at some of the nice watercooled setups with envy but I just know I would make a pigs ear out of it and leak everywhere and blow up my pcCheers for this but think I am properly set on that hard stuff for no other reason than how it looks. I have had soft tube systems before so fancy something a bit different, this is clearly where it all goes wrong isn't it... I am a sucker for biting off more than I can chew!![]()
Doh... gotta stop doing this quote instead of edit. Ahh well may as well leave you with some pics from my adventure:
What it looked like before it went in:
Some Vega:
What it looked like in there:
What it looks like now:
What this cat thought about the whole thing:
That last picture btw was taken seconds after I took the one above it. walked into the next room and there she was. Different cat this time but you can't fault that pose.
Close inspection of all of this at the end suggests that my card isn't making good contact with the aio towards the bottom left of that die shot as well as where the two chips are towards the top right of the die, I think they are VRM's. Well they didn't appear to be making good contact with the cooler either. I know I didn't make a mistake with the thermal pads and went over the instructions time and time again. I'm clearly not cut out for fitting this thing.
