Xiaomi Mi Robot. Search for the posts in this thread that talk about it.Dang![]()
To be honest I had read pages 8 to 12 and still none the wiser, I guess everyone here has different opinions and different needs.
Thanks for that insight, sounds amazing.it cleans up to the edge of things, unlike the ones which don't.
After 4years Arnie has finally bitten the dust so to speak. I'm hoping it's just a dead battery as it appears it's not holding charge and they are only £20 it seems so an easy and cheap fix. If it's not that then upgrade time!
Pretty sure it’s just the battery so should get another 4 years out of it hopefully, will only start looking at something else if that fails!What do you think you'll go for? LG announced some impressive models recently (maybe at CES?) but not sure when they're hitting the market.
It's a bit silly (depending on your budget) to go for anything that isn't a Xiaomi Mi Robot, as there is nothing as good in that price category. Spares are also very cheap.What do you think you'll go for? LG announced some impressive models recently (maybe at CES?) but not sure when they're hitting the market.
I never had any idea a v2 was released, and I will now read up on it over the next couple of days as the mop function would really interest me if it worked properly and didn't mess up carpets etc. I also wonder if a mop add-on can be gouth for the v1.True, I have the Xiaomi Mi and it definitely punches above its weight and I'm really happy with it. However, it's still interesting to see what manufacturers are doing to fix the short falls on robot vacuum cleaners. E.g. Samsung's Edge cleaning, as the common side brush doesn't really help all that much with carpet.
What's your opinion on the Rev 2 of the Xiaomi by the way? I feel like the mop function is a gimmick and there's only two to three improved features that are of any use (the pressure sensor on the LDS turret, the improved suction and increase in obstacle height it can climb).
I'm struggling to find out if they've implemented software virtual walls or if you can only specify a square area on the virtual map that you want the robot to go and clean. It sounds like it's only the latter.
I thought they could have moved the brush housing to the front of the bot (like Samsung, Neato, Dyson and the new LGs) as currently, the bot can only get as close to skirting boards as the distance from the brush to its side.
The Xiaomi Mi Robot would likely be a big improvement in those areas, especially the battery.I'd had a Neato for about a year. It's really cool to watch it roam about. It does such a good job I haven't used my Dyson since.
Still have to do the stairs with the handheld Dyson, still need one for the car and occasional jobs anyway.
I think the combination of a robot for floors and a handheld for everything else is ideal.
There's definitely room for improvement, it bashes into quite a lot of stuff, the battery life is barely sufficient and my house is quite small, the filter is a bit of a pain to clean.
The Xiaomi Mi Robot would likely be a big improvement in those areas, especially the battery.![]()
Link?their is a new version out of the xiaomi robot cleaner. supposed to be much better for wooden flooring and tiles, etc.
Link?
The existing one seems fine on solid surfaces? TBH surely solid surfaces are the easiest thing for them to deal with? Surely it's carpets and the like that are tricky?
I'd say the only area it needs improving on is getting close the edges and corners?
Looks very similar to the v1, and a built in mop doesn't interest me at all.
it now has a mop built in
