Why are OC not selling OEM i7 8700k ? But are selling overclocked ones at 5 ghz at £500 ?
Because the are using their OEM stock for overclocking to make more £££'s.
Pretty sure they said they took retail chips too because they got so few to start with.Because the are using their OEM stock for overclocking to make more £££'s.
And their retail chips stock.Because the are using their OEM stock for overclocking to make more £££'s.
money making for few minutes work and bit marketing like "not all chips can do 5ghz"Why are OC not selling OEM i7 8700k ? But are selling overclocked ones at 5 ghz at £500 ?
Is this avx issue on all boards or just certain ones?
I have the same cpu/mobo setup as you. I have found that even with LCC at 5 on the maximus board, I was getting 0.025V drops in voltage under load. I have now set LLC to auto and I am getting 0.015V voltage overshoot, but given that only takes volts from 1.3V to 1.315V it isn't a major problem.
AVX offset also doesn't currently work as expected on the maximus board. It downclocks even under non-AVX loads. I currently have AVX offset turned off and just don't run AVX stress tests.
Did you bought a normal chip or pre-binned? Is it delided?
What are your voltage, SA, VCCIO settins? Have you tried to overclock the Ring?
Whats your cooling and temps?
Pre-binned and delidded 8Pack 5GHz chip.
Well in the first 30 retail units only 3 couldn't do 5Ghz, the rest was like 5Ghz or above. Paying £100 more for that chance doesn't seem too good for me. Bright side is that you got a delided and 1 year warranty chip.
Are you going to switch from Ryzen to Coffe Lake? Surely if you want it badly you can find in available online. I don't know how many chips Ocuk have or they are going straight for binning.The way I see it, the pre-binned CPUs justify their price by dealing with the de&re-lidding hassle and you also get warranty on the chip.
Depends on the person if they're willing to pay the premium for that or not.
Personally I'd wait until availability improves.
I already have an 8700K waiting for me back home, found them in stock and close to MSRP at a Romanian retailer (but sadly they don't ship abroad). Going to build a secondary system when I visit and pick that one up.Are you going to switch from Ryzen to Coffe Lake? Surely if you want it badly you can find in available online. I don't know how many chips Ocuk have or they are going straight for binning.
Of course you know this do you lol ................ most do R15 1.35v or less 5.1ghz so you push 1.375 or 1.4 I think most will do 5.1ghz..................... Well in my testing they did and maybe I might know......Then doubt can go higher mate. Imho is better to roll the dice on silicon lottery than spending more money buying a chip knowing can do just 5Ghz.
When i go home tonight I will post my settings, which can be found few pages back.
I don't know if you saw my earlier post Ian but my binned 5GHz chip off you is doing 5GHz at 1.296v (AVX offset 2), 5.1GHz at 1.35v (also AVX offset 2) and then I can't get any further without weird AVX issues (multi dropping down to about 44 even with low temps). I've just left it at 5GHz AVX -2 now. Nice CPU though, and a HUGE improvement over an FX8350.
@Panos Thanks for taking the time to post your settings mate, I appreciate it.
But it pushes the CPU to it's limits....
