Caporegime
- 9 Nov 2009
- Planet Earth
So the MSI is the best for CPU overclocking and the ASRock for RAM overclocking!
Thanks that was good vid.
If only the msi one wasn't so ugly lol. think I will still get it though.
The ASRock seemed better for the memory part though. OTH,looks like your current MSI board has served you well!
Yeah my msi board and 3570k I had since release bought from here, even overclocked it to 5ghz for some benches on air and had it at 4.8ghz 1.4v for few years done me well.
Not sure the high memory matters as I already ordered some ddr4 16gb 2800mhz. I was going to get faster but it was going very cheap new.
Faster RAM gives a boost,but its not proportional to the cost ATM anyway,especially if you are getting a Core i5 8400!!
Can't really compare those scores, they are using different versions of cinebench
I just got the asrock as it was the cheapest at the time (~£100) and there didnt seem much in it (ie pros and cons for both). Also the asrock has one more rear usb3.0 and a usb c port which the msi doesnt (has a couple of usb2.0 instead.
Probbaly worth getting whichever is the cheaper at the time to be honest, espeically as its unlikely you will be doing any mad overclocking with an 8400 anyway.
yeah I will get which ever ones cheapest probably.
I do plan on maybe upgrading the cpu in a couple of years by swapping out the 8400 for a 8600k/8700/8700k if it I need it.
if you planning on changing chips in a year or so, depending on the games you play buy the K chip i3, the new i3 is a true quad core and with many games still only using 2 to 4 cores the overclocking would give you more performance.
the i3 as been seen to hit 5Ghz easy
Your 3570k is very old now and the performance of the i3 I would think is going to be 30% better.
I would like to see some test on the i3 @ 5/5.2ghz Vs the 8400, I think it would be 50/50 as the single core upto 4 core performance of the i3 would kill the 8400 but as you say when you need more cores could the overclocking help the i3 keep up?
I would pick the 8400 over the 8350k. Although I wouldn't pick either at current prices, especially the 8400 which is £30+ too expensive currently.I think clocking the i3 would help a lot but when all 4 cores get loaded games normally get a bit choppy, I know a lot of people on here have said it's much smoother with more cores.
Just need to somehow find a Z370 board for B360 prices, and that's an incredible bundle. Finding the reasonably priced RAM could be a hassle though.I just got the 8400 for £160 delivered off MM![]()
https://www.overclockers.co.uk/inte...e-socket-lga1151-processor-oem-cp-649-in.html
More like £75 too much for the 8400 and £50 too much for a motherboard. £325 for the chip and board. You could get a 1700X and decent B350 board for that.
