- 14 Jul 2011
Thanks i tried all that before i posted here. It is on a clean win 10 install but maybe al updates have to be done with windows updates before installing these drivers. It hangs the pc
I'm now happier with my air reference V64 than I was with the AIO version and so far my 650 watt psu seems to handle it fine. I was worried it was starving the card as it wasn't going up to 1600 let alone the stock 1630 mhz it's meant to be at but now I think it's more to do with temps as I've improved those and it now passes 1600. I ordered an 850 watt psu so tomorrow I'll see if it's any better with that as the stock clock should be 1630 mhz. Plus I'll see about overclocking once I have that installed. You're doing really well running all that with a 600 watter.
Just use Power save profile for tiny performance penalty compared to third lower consumption of card.TBH the power draw of the 64 scares the bejesus out of me!
You forgot to count in price of very probable need to replace it sooner than if you had bought PSU with quality components....Be Quiet! Pure Power 10 600W...
I would expect the real world speed and stability of the voltage regulation control loops varies with PSU models, and the larger output capacitors in high power PSUs can somewhat mitigate a poorer response. I may have accidentally lucked out in getting a fantastic quality PSU, but I chose it as I thought it was a good deal at £65 earlier this year. It's only rated 80 Plus Silver, but crude efficiency isn't intrinsically correlated with other quality or performance factors.
Damn RX Vega 64 is only 4 FPS @ 1080p and 8 FPS @ 4K behind GTX 1080 Ti in Wolfenstein II.I wish they optimized all games like this for AMD cards.
http://www.guru3d.com/articles_page..._pc_graphics_analysis_benchmark_review,4.html
http://www.guru3d.com/articles_page..._pc_graphics_analysis_benchmark_review,5.html
Thanks i tried all that before i posted here. It is on a clean win 10 install but maybe al updates have to be done with windows updates before installing these drivers. It hangs the pc![]()
BF1 4K60 Ultra Settings Vega 64Vega 64 can handle BF1 at 4K60FPS Ultra Settings very nicely.
Hopefully its a sign of things to come. I want to see more devs start using Vulkan API though. I know Star Citizon said they was going to use Vulkan.
Star Citizen never going to come out though.![]()
Turning to custom and turning off taa as it's overkill for 4k, should give you 15-20 fps, which is solid for vega. But can't really compare mp, or with vega at dx11 and nvidia at dx12.BF1 4K60 Ultra Settings Vega 64
1080TI for comparison on the same map and same settings.
Fair point, i missed that will edit my post to add the video below on DX11.Turning to custom and turning off taa as it's overkill for 4k, should give you 15-20 fps, which is solid for vega. But can't really compare mp, or with vega at dx11 and nvidia at dx12.
In those videos.
Not taking anything from your video though, Vega was absolutely solid in your video.Fair point, i missed that will edit my post to add the video below on DX11.
That's okay, thanks for pointing it out it was a valid point.Not taking anything from your video though, Vega was absolutely solid in your video.
Vega performs really well on BF1.
Lower end parts of second tier maker aren't good thing for longevity especially when cooling isn't maximized and efficiency is substandard.
The electrolytic filtering caps are provided by Teapo. Most of them belong to the entry-level SC line...
http://www.tomshardware.co.uk/be-quiet-pure-power-10-600w-psu,review-33932-3.html
