Thread twist - OP built his own house.
agreed, health warning needed.This thread should come with a warning on P1. Just read 4 pages of absolute bile and now my head is spinning![]()
I assume he means run through, main drains, main sewers, or supply to properties behind them, or existing large scale storm drains.
I assume....
after being reminded by my mrs that "wasn't we told we didnt have drains". I queried it.
Unfortunately he isn't good at explaining himself and apparently talks like this:
Which probably doesn't help.
So to recap, they've forgotten to fix your inspection hatches properly and you've been demanding the plans to the property in response as opposed to just asking them to pop round and fix the inspection hatches?
Yea, it's everyone else that's stupid.![]()
I'm really not sure what is so difficult to understand from this. No one is saying our property isn't hooked up to any drainage points. Do you honestly walk down the street and call a drain, a drain cover opposed to a drain?
Actually I said to them:
"I believe these aren't meant to be here based on what your sales staff told me, so if that's the case, can you show me the plans and remove them. If that's not the case, can you show me the plans and fix them."
Either way, no plans have been shown.
Yes. Using the correct terminology will avoid situations above.
Using your own analogy. The developer was right. The drains aren't visible!
So what did the developer tell you? Drains or drain cover's
