Caporegime
- 30 Jul 2013
I assume he means 'Origins'
So do I, which is why I said what I said.
AFAIK from what I’ve read there’s no additional textures or anything for it.
My one x turns up today! Just need an excuse to go home early.
Forgotten dentist appointment sounds like the ticket![]()
Yes hard reset done, tried install online and offline with 3 different game discs and all still stop. Either after a few hundred MB or a few GB have installed. Ask it to resume and it carries on for bit but then does installation stopped again. Downloaded some demo / trail game and don’t seam to have issues from some I tried. So maybe the console as a disc drive fault and can’t transfer the data correctly onto the hard drive? Just gutted that I am going to have to return the Scorpio as I like the look of it plus the added bonus of the vertical stand. Will pick up another one from John Lewis tomorrow. Fingers crossed that won’t have the same issue.All the ones I had a problem with were digital versions.
The one physical version i had Deus ex did the same but I found it was because my host one s kept shutting down after awhile that it would **** up the transfer.
So you tried a hard reset and still you get the install stopped error when trying to install off disc?
(loads of little party style games, local MP)Enjoy, it's actually got me playing Xbox again which is an achiement in itself!
Got PUBG pre ordered last night, £22 from Amazon.
Poor choice of using Assassins Creed considering it’s not a 4K game with 4K textures.
Anyone tested battlefront 2 yet?
How can you? I thought you could only play it 3 days early and it's not out until 17th?
I cancelled my preorder for this because I have a decent PC already but for some strange reason I still keep considering it, especially since I can see them in stock still. The problem for me is that I'm only really playing Forza 7 at the moment so there's literally nothing to be gained for me. Anyone else as foolish as I am?![]()
Just clarify from later post I was referring to Assassins Creed Origins.
Why is it a bad choice of games to compare? it's one of the games that MS were pushing as a 'featured' title to show off the X performance. There are 6 games listed by MS as featured X enhanced games: Forza 7, Assassins Creed, GOW 4, Shadow of War, Titanfall 2 and Tomb Raider. I have all of them and think I've covered them all in previous posts.
