He's probably bitter that he couldn't afford one.Take no notice he is just trying to stir things up... he is probably posting the same comment in different forums.
I have to agree, owning both I much prefer the design and compactness of the Xbox X, side by side the pro looks ugly and huge, I did not particularly like the standard PS4 design either.
Hopefully the next console from Playstation will be completely different.
I just found the exact same comment he posted here in the youtube video comments i posted above. Deja vu.
I quite like the Pro Design however it does look bigger than the X, however the X is actually slightly wider, just looks smaller for some reason. In reality we have the PS4 to thank for the X design as without that MS would still be making the VHS Recorder box (they took a lot of criticism for the original Xbone).
It looked fine until I had them sitting side by side, anyway its cool owning them both.
Unless the measurements are incorrect, the 1X is significantly smaller than the Pro in cubic volume.
I was always hopeful that it would, but doubted 60 frames at 4k. But with destiny the dev is locking it to 30 by choice across both platforms for some reasonDestiny 2 - Native 4K on 1X.
So much for 1X can't do native 4K in these kind of games.
The most powerful console in the world! Plays games at 30fps, pathetic.
they've limited it to 30 because the consoles cant maintain 60 fps.
lol, what were you expecting? 144FPS? Be realistic.
I suspect even the next generation will have its fair share of games at 30fps. Just a characteristic of consoles. Although we seeing many more games at 60fps this time around compared to PS3/Xbox 360 so you never know...
It's only really the CPU holding the One X back now, they could just update the CPU to a newer architecture (i.e. AMD Zen) and keep the same power GPU and it could probably run most 30fps games at a locked 60fps with a dynamic resolution in place.
