Easily 7 with that new engine. What's interesting are the different spec bits. I thought Mercedes locked in some engine changes prior to the new oil burn rate to take advantage of that. It looks like now they've won they've got some free testing on a lower oil spec machine.What's folks guessed on the value of these parts. Must be close to 7 figures
That's f1 for you, very rarely been anything else.This race really showed up the implications of the current rules. The whole race was dominated by the effects of cost cutting and consequent unreliability. It was not a formula 1 race.
Six cars were limited by unknown engine problems and the resultant de-tuning (Renault, Torro Rosso and Red Bull). Two cars limited by last years engine due to bad payments from the championship (Sauber). Two cars with the best engine were hindered by a lack of funds on the overall car (Williams). Two cars limited by political disagreements between engine and car manufacturers (Mclaren). Two cars limited by lord knows what (Haas) !Add to that the failed cars involved in collisions for minor places leaving us with 2 Ferraris and a Mercedes that followed each other. The only car doing what a car should do in a F1 race was one Mercedes.
I wonder if Liberty see it that way?
Andi.
It must be really frustrating for the promoters of the final races. Not only have the championship been decided everyone put there in a sub standard car.That's f1 for you, very rarely been anything else.
The future is bright for F1 audiences if over 20% of this forum consider this race 8/10...
That will be because Ferrari won plus Lewis and Danny R were heroic. The rest was predictable.The future is bright for F1 audiences if over 20% of this forum consider this race 8/10...
Mercedes were already at the lower oil burn rates before the other teams. At least that was what I got from Wolf when he was interviewed around the time Ferrari and others were bringing in their updated engines.
An FIA spokesman said: "If an engine [ICE element] is introduced at or after the Monza race weekend, its oil consumption needs to be below 0.9l/100km whenever it is used.
"If an engine [ICE element] has been introduced at or before the Spa race weekend, its oil consumption needs to be below 1.2l/100km whenever it is used."
The FIA deems an engine has been used as soon as a car's timing transponder has been triggered by leaving the pitlane.
I remember the fuss that was made at the time, but like englishpremier said, Wolf did state in at least one interview that the current spec engine was already comfortably below the new 0.9l oil burn limit, whether or not that was entirely truthful (in all engine settings...) i dont know, but the new engine that did require to run to the 0.9 limit showed no sign of being any less powerful, if anything more so... however that may have been because they could run it in higher engine settings for longer considering it only has to complete 2 races.
He did say that but the FIA allowed them to run the higher limit, so it’s kind of a moot point.I remember the fuss that was made at the time, but like englishpremier said, Wolf did state in at least one interview that the current spec engine was already comfortably below the new 0.9l oil burn limit, whether or not that was entirely truthful (in all engine settings...) i dont know, but the new engine that did require to run to the 0.9 limit showed no sign of being any less powerful, if anything more so... however that may have been because they could run it in higher engine settings for longer considering it only has to complete 2 races.
If that was the case it was suggested Mercedes would have to comply with the 0.9l limit when its customers moved on to their final engine.
Ahead of this weekend's Italian Grand Prix, the FIA has confirmed that Mercedes will only have to comply with the 1.2l limit that was laid down in the technical directive - because the engine has already been used.
Ah, even so, those new specs are surely testing some 2018 requirements. They've only got 3 engines next season so making the things bullet proof is going to be pretty valuable.Mercedes were already at the lower oil burn rates before the other teams. At least that was what I got from Wolf when he was interviewed around the time Ferrari and others were bringing in their updated engines.
He said that the engines weren't running the higher oil limit and the FIA allowed them to run the higher limit anyway. So...It's not a moot point, if the engine was designed with heavier oil burn in mind then it wouldn't have run comfortably without it. If oil was the reason they were so fast then running less than that amount would have been detrimental.
