- 14 Nov 2017
Don't get that PSU - it's another low quality cheap unit with only a 2 year warranty. Don't ever skimp on the PSU, as it can take out your entire PC.
Get one of these instead:
My basket at Overclockers UK:
ok thank you
I wil definitely take the advice onboard what are your thoughts on this one?
https://www.overclockers.co.uk/kolink-core-series-700w-80-plus-certified-power-supply-ca-02q-kk.html
thanks
Never go with a cheap non brand PSU, I did once.
loading to windows and installing the driver's where no problem either, but every time I tried to play a game or even run furmark it would shut my whole computer off (as if I'd pulled the power cable out) then it would restart on itself and load back into windows without any error messages.
I think at the moment crimbo wise and budget I may be better getting a lower priced gpu and spending more on the psu the kids at most wanted to play ARK so maybe something that is capable of that? would any of the 2gb nvida cards be enought?
Ah...CiT...
That freaking time bomb need to be removed from your PC asap!
It could be either the PSU or the GPU, from what he's said it does sound more likely the GPU however the PSU still needs replacing as he's using a grenade level unit.Why has this thread become obsessed with the PSU when it seems much more likely that the GPU is the problem?
Would this be a good choice? I can stretch to it.
https://www.overclockers.co.uk/kolink-kl-600-600w-80-plus-bronze-power-supply-ca-012-kk.html
I wouldn't get the 1050ti. I would get a 1060 and get a PSU later if needed. That's just me though.
Black Friday is coming up, so you might get a good deal on a GPU or PSU near the end of the month. It might be worth waiting a couple of weeks to see.
True hopefully it was just the GPU then.
would you say this one?
https://www.overclockers.co.uk/pali...ddr5-pci-express-graphics-card-gx-03o-pl.html
I got the same model 1070 and it's fine. Palit are pretty good actually.
But, did you read what I said about black Friday? If you aren't in a rush to buy maybe you should wait a couple of weeks to decide?
Yes I did thanks, I can wait I'm just concerned about the PSU a little now :S
Thanks
Sorry if I wasn't clear, what I meant was the label itself claim it can deliver like around 300W ish over 12v rail on a 700W PSU, and the reality they cannot even achieve that claim.Why has this thread become obsessed with the PSU when it seems much more likely that the GPU is the problem? Yes, CiT aren't the greatest PSU makers, but then you have the horror stories being relayed here of the 12v rail only supplying 40% of what it's meant to do, well, even if that is true, it would still be enough for a 970/1060 system.
Yes, a decent PSU is always smart, but first solve the actual problem of today, then work on the next weak link, which is likely the PSU.
