I bought that on the cheap a while ago, really enjoyed it, seemed to fly a bit under the radar.
Might go back to check out the X enhancements.
Yeah i am enjoying it so far and it looks very pretty.. worth a shot now it has had X enhancements
Got my X set to 12 bit , says it’s compatible with my tv .. is it better to stay 10bit then ?Seriously? I have that exact same model in 55" and 43". These TVs just updated to android nougat a few weeks ago. Awesome stuff. I've got my one x set up as 12 bit, suppose I should set it to 10-bit...
I found it boringHi
Is mirrors edge catalyst worth a fiver ?
I am using a 4tb Seagate Expansion usb 3.0 drive on my One X, works really well.
Decided not to go for the MS green xbox branded one.
Cheers all
We have the same tvSo tempted to get an X for Xmas, is it worth the huge chunk of cash over the S? I bought a Samsung KS7000 earlier in the year specifically for 4k/hdr gaming and am now debating the cost lol.
I thought wolfenstein 2 was HDR but it seems not?
How do I check a game has been patched with the X enhancements?
No HDR on wolfenstein 2 according to the microsoft site.
https://www.xbox.com/en-GB/games/xbox-one/xbox-one-x-enhanced-list
Go to my games & apps section and in the top right corner you can filter your games into xbox one x enhanced games and it will display what games have been updated.
I didn't know what to set my xbox one X too so I left it set to output 36-bitTrue dat:
Note: Current TVs max out at 10-bit color, but sending a 12-bit signal helps to allow processing (like white balance adjustments) to be enabled without adding banding.
http://www.rtings.com/tv/tests/picture-quality/gradient
I was expecting more from wolfenstein after the reviews and praise in the forum's. Looks good but I wasn't sat there thinking it looks better than halo 5 or gears 4We have the same tv.
I thought wolfenstein 2 was HDR but it seems not? Or am I being silly? How do I check a game has been patched with the X enhancements?
