- 3 Oct 2009
- Wales
Mine seems to be getting gradually worse at recognising my voice.. Anyone else experiencing this?
You need to specify the Plex media player as the dotJust removed all skills, then unregistered the dot. Re-registered it and then before doing anything else added the plex skill. Asked it to play some music and it said it had set the correct server and will play the music I wanted, but nothing. The Alexa app again shows it heard correctly and had started the music!
So frustrating.
Logging it on the Plex forums now as there also appears to be others reporting the same issue.
Spam -
Set the Plex Player
The last step to preparing the Plex integration with the Alexa Voice Service is to set the default Plex player. Say:
- Ask Plex to change my player
You also need to be logged into the admin account
Seems to be an exploit with the Spotify connect.
Have disconnected my Spotify in the meantime.
https://community.spotify.com/t5/De...b-0-2-1-hijacks-user-accounts-to/td-p/1178793
I really need to start using mine as an alarm clock in that case. I'm useless in the mornings and having to put effort into stopping something could be what I need. I can usually mash my phone in my sleep and turn it off without knowing.
Spam -
Set the Plex Player
One thing that has disappointed me is that you can't setup an option to put the radio on as part of a routine. I've set up a "morning" routine, and all it lets you do is go through the news, traffic news, and then weather. Hopefully the ability to start the radio up will be added in an update.
So frustrating.
Just got a Dot for the living room and the sound it's surprisingly decent.
However, partner would like music in the kitchen so the obvious solution to this is to get a Bluetooth speaker, pair it with the Dot and have the speaker in the kitchen.
But then the speaker on the Dot itself wouldn't work, would it?
We'd like to keep the dot in the living room and have it Bluetooth music into the kitchen.
It seems a bit of a pain to have to manually connect/disconnect the Bluetooth speaker when we are cooking and want sound in the kitchen. When the rest of the time the dot speaker is just fine for in the living room
Good to know you got it sorted! That'll be why it worked on mine as I don't have UPnP enabled.
Does it not make more sense to just get another echo?
Failing that
Alexa connect my speaker or Alexa disconnect my speaker doesnt take long to say.
