- 18 Oct 2002
- Stone, Staffordshire
Can anyone help me with my configuration.
I've just moved over to Vodafone fibre this week so I have 2 LAN cables in the router. 1 to the network switch for all other wired devices and 1 to a Unifi LR AP.
I've bought a Ubiquiti USG to add in to the mix but I'm struggling to migrate it into my network.
1) The default IP is the same as my core home server so I've isolated the USG and changed its IP to 192.168.1.253
2) My vodafone router is on 192.168.1.254
3) 192.168.1.1 is used by my main home server.
With the USG adopted I disabled DHCP on the vodafone router and then plugged LAN1 from the router into WAN1 on the USG
LAN1 on the USG is connected to the network switch
LAN2 on the USG is connected to the LR AP
Once restarted I lose all internal and external network connectivity!
I can access the USG and get the message that there isn't an internet gateway present and I'm prompted to complete some details but nothing I've tried works.
Do I need to ditch the router for a pure modem instead of scaling back the routers functionality by disabling DHCP?
