You can in my wife's car. I haven't tried it in mine but I'm assuming what you said is right for mine as it's an electronic shifter whereas my wife's is mechanical.You can't put it in gear to drive away without a key present.
I saw said person a little while ago so asked him what car, it was a golf, so VW
He said he had no warning which he thought was odd as in his 3 series it complains when you get out with the key
Could you disable it maybe, could be a reason why a hire company may want to do this? Cant think of one but there may be a reason why would
Could be interesting to see what the ranges are, eg on top of a petrol pump could be a lot closer to the drivers seat than say in a coat pocket in the boot.
Distance from the drivers seat should be irrelavent, even the early generation systems had the technology to determine if the key is inside the cabin or not, precisely. This isn't just for engine start, it's for locking too. If the keys are inside it won't let you lock, keys outside even if it's touching the door skin, you can lock. Not sure how it works but it's clever. You typically can't shut the keys in the boot either, mine would pop the boot back open if you closed it with the keys inside.
