- 29 Oct 2017
- Lincolnshire
Crisis over![]()
yep, now its just a case of how much airflow i've just sacrificed for the sake of it being so god damn pretty.
Im changing from a phanteks enthoo pro m glass but itll be a liquid cooled custom loop when i'm done and i'm still waiting for news on the rog formula x z370 availability for my 8700k so itll also have vrm cooling from the ek block. Ive just got to hope its got enough airflow to cool the board and other components without also suffocating the 2x 360 mm rads i intend putting in it. I think it'll have enough breeze not to cause any issues..
It sure does look pretty and its nice to see it featuring a proper usb 3.1 type c port/header. The only things id change based on looks etc is the black trim around the tempered glass on the white version should have been white trim and the io cover for the front panel looks to be a bit flimsy, it wouldve also been nice to get fans at top and bottom of a top mounted rad as it has a glass top that is screaming out to show rgb fans from above view but if you use a rad then there's no space for fans in push/pull to show rgb fans on both inside and outside of the top of the case so you have to sacrifice rgb fan view from one viewing angle, the gap between the top rad/fan mount and top of case isn't quite large enough to fit a second set of fans sadly (may also choke them of air even if you could get them in there), but overall it looks a stunning case with very nice vivid addressable rgb fans along with a nice controller with over 300+ lighting modes/effects.
Cant wait to get my hands on it! ill update and give me review/verdict on here once i do
