Snow stories!
28 Sep 2012
Monterrey, Mexico
I know they are, hence why I take them with me! I’m surprised Geekman didn’t take chains though!
Sorry, I thought this thread was about stupid things we did in the snow, not well prepared trips that went without a hitch? :p
At the time, I was only living an hour or so away from the alps and my (flawed) logic was that if things got a bit tricky we'd just turn back. If I was doing it again, I would definitely bring chains and snow tyres.
1 Mar 2010
This is true, overtook a honda civic earlier doing about 20 on a perfectly clear road, when a bm on summer tyres is passing you in weather like this you've probably misjudged it
The ruts of snow in the middle of the A road were a bit problematic on Sunday morning for overtaking the 40mph traffic, don't know how much rwd may hinder this, but cannot change down and accelerate past as you might do in dry conditions, the adherence inbalance makes it tricky. ?
Got the 330d up to Val Thorens multiple times on summer tyres
a couple of 25KG bags of sand in the boot were always rumored to help up the lacets to ISOLA 2000 resort.
...poetic justice this morning in the freeze 2 miles of A road into town, sligtly off camber bend, renown, but they never learn, in daylight one car in the ditch at 8:20am and another one joined it about 30mins later as I returned, builders van and central heating company, a few big grave-stone signs would help after a mortality a few years back.
18 Oct 2012
It was completely clear, just a wet road (with a ton of salt), wouldnt have even tried if with snow ruts
5 Aug 2013
Shropshire
Went out sunday morning to give snow tyres a run and came up behind a slow coach - nice straight road (A41) both ways were clear but slush dividing two lanes - so pull out and found it wasn't slush but ice slush - wiggled a bit but got over it - passed slow coach and now how to get back in - put a spurt on - got some distance and pulled over - wow - it pulled me across and hit clear bit of road doing a nice tail wag - next time I will follow the pack.
1 Mar 2010
I wonder if the adhesion differential between tyres on wet and icy patches is greater with snow tyres, wouldn't the tractionstability control on newer vehicles not help with such a manouver too ?
(when top gear was about cars, remember them showing merc testing with one side of car on ice, the other dry)
I did not start the overtake via rut, because, indeed, I was afraid about being stuck on the wrong side of the road, looking for a way back.
Caporegime
25 Jul 2005
Canada
The opposite to that. With Winter tyres the differential would be less as the there would be more grip on the ice than a normal tyre, therefor making the grip more similar to the wet road.
5 Aug 2013
Shropshire
I did do a try stop on ice in our road before got to main road - ABS came on and kept going - I have used them for 4 winters without any snow here and they are down to about 5mm compared to the original 8mm - it wasn't so much not having the grip crossing center ice slush as more the slush was so hard it moved the car around when you went over it and dumped me back on cleared bit of road.
In the last snow 4 years ago we were out in it - coming home in virgin 2-3" of snow the car seemed like it was on wet road - It went round corners rather than sailing straight on - I was very impressed then - bare in mind it wasn't icy.
Nearly all gone now so hope that's it -
31 Oct 2004
London
What? Winter tyres don't grip on ice, they just perform better in the cold weather.
1 Mar 2010
hypothesis was : that in the wet sections could be too warm for optimal winter tyre use, so all season would grip better; but the winter tyre on the other side of car would grip the slush/ice well, giving a larger differential.
But after looking it seems 7C is the cut-off point, anyway if the slush were colder than wet section, manouver would be too fast for the tread to 'respond.' (with additional flexibility)
Also I guess manouver is too fast for any stability control to help much to compensate for differential, or save the day (per year it might be an issue in the uk)
Caporegime
25 Jul 2005
Canada
And they perform better on ice. They still don’t provide ultimate grip, but they provide better grip than a summer/all season due to tread and compound. It’s one of the things they are designed for, why they aren’t actually called “snow tyres” and why they are essential in places where people drive on ice for much of the year.
They’re also better on snow because the tread is designed to “lock” the snow into the tyres and use that to grip the snow on the ground.
Yeah, you’d have to have a massive temperature differential, which is unlikely to ever be the case. Also the drop in grip from an all season to a Winter will be minimal, even above 7 degrees, it’s mostly about wear, and the winter will have a tread better designed to deal with removing the slush from beneath it. So half on, half off, a Winter tyre wil grip the same or better on the dry road and better on the snowy/icy berm.
