First time building gaming desk mod!
9 Dec 2017
Hey everyone, just wanted to show my design for my desk i am currently working on. This design is juts a ruff draft and it might change in the future. Hope you guys enjoy and ill be trying to update weekly! I have some of it built (just part of the frame) and ill post pictures further i get. Have a good one!
0fcK72U
Just for the looks mainly
you don't show a gpu? are you not cooling it?
including unnecessary bends etc will negatively affect the flow and ultimately the cooling ability of your setup. cooling hdd's is completely pointless imo.
edit: where you show the motherboard, I assume that's both cpu and gpu cooling then?
Yes I'm cooling the gpu as well, I just didn't put it in there......I just want to cool them so it will look aesthetically pleasing with the tubing around inside the desk. Might be pointless but will still look good ;)
it might look good but it may have a detrimental affect on the loops cooling ability, but it's your rig. hopefully it all works well and looks well.
what are the specs going to be?
Ill monitor the temps and all that, if it is ill re do the tubes.... Ill have a
Asus maximus ix extreme
1080 amp extreme
i7-8700k
32gm ram
2 TB HDD
2 EK coolstream xe 360 Rads
2 alphacool dpp655 pumps
2 or 3 Alphacool cape corp coolplex HF metal 25 reservoirs
1080 amp extreme
i7-8700k
32gm ram
2 TB HDD
nice. should look sweet. you got a particular colour scheme in mind?
Here is some of the progress so far! Still a LONG way to go but its fun! Ill post some pics of all the components that are going into it once i get them all. Enjoy!
Nice work.
Have you considered some kind of vinyl wrap, not sure if that would be an option but it would be worth a look. You could also cut/stick a full coloured perspex sheet over it.
Nice work.
I thought about it, but I'm just going to paint it flat black and the inside floating board will be carbon fiber vinyl wrap.
What about the top, clear perspex?
The beauty of such builds like this you have the option to adjust and tweak later on if you so wish.
Great project, I will be watching your progress with interest and I'm sure if you contacted some websites or magazines they would be interested.
I had a build customPC a few years back, not sure if they still do the readers build section.
