I have had my belkin ups for about 8 years now and your not suppose to change the batteries, but I do anyhow. Having changed the batteries about 4-5times now, its still a tad nerve racking taking the metal case off and on, because theres a board almost touching the top of the metal case. So if the case touches the board, it will short and burn the board, as there is always power running through the ups until you disconnect the batteries.
So I was thinking of gluing something to the top of the case, so if the case touches the board it wont short and fry the board. So guys whats the best stuff to use to solve this problem. Thanks
Heres a pic that I found of the ups with the case removed and you can see how close the board is from the top of the case.. The removable case is the same as the old pc cases use to be, top and sides are all in one
		 mine do at least 5 years - and though I probably should change them more often some can probably hit 10 before there is serious capacity fade (EDIT: Or complete failure).
