- 6 Sep 2016
I'd expect you to be looking at a lot more than £200 for a UPS like that.
The batteries alone for a 1500VA UPS are going to consume most of your £150 budget. They're either going to be significantly larger than the batteries you've had so far, or there's going to more of them. Don't forget that you'll be hit with that cost again every time the batteries need replacing.
Why are you running a UPS in the first place?
Why true sine? Is this just the usual spec creep we can all suffer from?
Actually the two batteries in my APC Smart 1500 were £75. That's by getting off the shelf Yuasa batteries, of the same size and specifications as the original APC battery pack. Takes about 10 minutes to stick the two together, fit in the fuse and wire, and hey presto just saved yourself fair bit of money.
it tells you how quickly it can deliver power if required.
