Thanks for the info. From the top then, you've had access to your brother's Rega P3 system to listen to over the past 15 years. QUESTION: What's he running with that TT (cartridge, amp, speakers etc) and how does that sound compared to yours?
QUESTION: Is his room size and gear layout significantly different to yours?
From the picture, it looks like the speakers are pointing at different angles. QUESTIONS: Is that correct, is there room so that they could they be made to point in to the room at the same angle?
QUESTIONS: Do the wall brackets hold the speakers rigidly, or is there some flex, or would they swing easily from side to side if pushed gently?
It looks like one of the speakers is pointing down slightly compared to the other. I take it that means the wall brackets have some adjustability for vertical angle?
Before changing your speakers, it's probably a good idea to see if we can get more from the ones you already have. QUESTION: Is it possible to get the layout so that both speakers are pointing almost straight ahead and at the same angle horizontally?
