Finished second tonight, against a guy whom was following me through walls, Instant head shot with AK with no recoil. Oh the joys.
makes no difference.all anticheats are the same since fps games came out.
so it wont effect the playerbase at all.its not that bad.if you stick to europe.go asia and na you will see more if you a regular top ten person.
it just means a certain percentage will cheat always.wont matter if a small percentage cheat when 20 million are playing legit.
last ten games i had 3 wins 3 or 4 2nds couple top tens.not one cheat all euro.
you do get em but it isnt as bad on euro as many make out.
it will eventually just get to the similar percentage of cod and battlefield which is about 10-12 percent of the player base.thats standard.
Yeah but as I've said before, in any other game you can switch servers or votekick, in this you've invested 40 mins of your time trying to play against someone that can see you through walls constantly.
Also wouldn't your elo rank affect how many cheats you see since they are in the top tiers of ranks.
