- 20 Jun 2011
- Livingston
Any chance of some photos of the PCB?
Are you sure it’s the card and not your pci slot?
but does it work as a lubricant, even if only short term?However using it as a lubricant isn't it's primary job
In terms of rust, again it isn't for removing but for breaking the bond between the metal and the rust.
Water can be used as a lubricant too but I'll leave that off my hinges?but does it work as a lubricant, even if only short term?
thus allowing the rust to be removed, sounds a lot like a rust remover to me
WD40 won't rust your hinges so why use the comparison?!Water can be used as a lubricant too but I'll leave that off my hinges?
Wd is a strange jobby useful but awful at thousands of things a bit like a liquid duct tape. You're far better off with the right stuff but not everyone has space for 4 types of lubricant, a dedicated rust remover and a light oil in their toolkit with them.
aww come on, how is it not?Sorry but that's literearly not the same thing.
WD40 acts as a lubricant? yes?
WD40 breaks the bond between the metal and rust thereby along the rust to be removed? yes?
it'll take some fancy word gymnastics but go ahead, tell me how it's not.
edit: did you actually need to use the word 'literally'?
wow. you've spending a lot of effort trying to say it can't be used as a lubricant and then saying it can.snip
don't point them towards this thread whatever you do!Palit finally got back to me and told they dont handle warranty claims/repairs from end users so i guess i'll have to contact OCUK and see if they can do something.
