PLAYERUNKNOWN'S BATTLEGROUNDS - Thread
the funny thing is i only hipfire in every game i play :eek::D
you do that as it saves you split seconds that often gets you the drop on someone.many oldskool players just crosshair shoot without aiming up for that very reason.
TBH I've noticed theyve reduced the accuracy of hip fire, you used to be able to abuse it instead of ADSing when lying down in grass, with 1.0 theyve upped the spread on hipfire, which is why its now even more obvious when its being used when cheating
Probably stupid question here, but how can you tell they are cheating? What should I be looking out for?
In the actual game you don't get to see massive big tags above everyone's head and the player is looking straight at people's positions when they're not in view.
So is this likely cheating or not? Hip firing, instant headshot...
Three of us suvived to the end against one other squad, who wiped us quite easily. (Granted, I deserved to die, getting caught behind in the blue...)
Had this for a while now but i have an issue that you lot may be able to help with, When diving down from the Plane its very stuttery, However when im finally down on the ground and its perfectly fine, no issues what so ever :confused:
Any suggestions
Pretty blatant cheating imo, look at the way the aim snaps whilst he/she's firing through the window frame.
Got headshoted twice by this guy (https://pubg.op.gg/user/hdyeu386jgusyewn?server=eu) yesterday in the death cam was a hip fired scar from 220 m, what I don't get is how sometimes his stats are mince?
His stats just shows that he toggles, either doing 0 or ~1000 damage. You can be a good player and do that damage, it's his HS percentage that is the biggest red flag. He's at 70%+ HS ratio, best players in the world don't go above 30/40% in this game.
^ Yes blatantly cheating, can check stats here too https://pubg.op.gg/user/suzixuan04511?server=eu
I think what happens is that some cheaters get paid by other legit players to play with them to boost their rating.
CSGO actually deletes game stats with previous cheaters in queue when caught, would be nice if PUBG could adopt that also.
Love that site, not seen it before... although it shows up what a useless team mate I can be at times! I'm definitely getting better though. I don't often solo, but I just had a quick one and got 3 kills purely by being very patient, which is usually my downfall. I finally died I guess because I wasn't patient, but maybe also I kept my long range weapon equipped when going to get the loot from kill 3. Still, I'm trying to learn from each death :)
That game we got beat by cheats was a shame as we'd worked really well together as a team, moved well, attacked as a team so it's rather annoying to after all that, then be beat by cheats :(
Clearly I'm better in FPP as my HS is 42.9% (granted, it's only over 13 games :) )
Ah ok, well the animation doesn't seem like they are hip firing! Obviously they are not ADS as we can see, but the character pose looks like they are!
They're "third person aiming" by holding down right click. I called it hipfire, which I guess is a mistake since hipfire would be just shooting without holding down right click.
Either way they are not ADS/scoping in like every other play would do at that distance. The bullet spread is too large to third person aim at anything over 100m, PU even said it himself in an interview a while ago.
you obviously never played played oldschool shooters.quake twich shooting at speed of light.practice its easy.as said all games i do it.
Old school shooters are mostly hitscan with no random spread.
ADS is the only way to get your bullets to actually hit the center of your crosshair in this game reliably. Third person aiming has random spread which blooms the more you fire. Even if you let your crosshair reset the bloom it isn't as accurate as ADS. It's objectively bad to third person aim in this game unless you're at very close range.
if it works it works.i been doing it for twenty years in all games.90 percent of this game is at 50m or under fire fight wise.hipfire works.obviously sniper rifle or 200m+ shots you dont hipfire.common
sense.
use lower recoil guns + hipfire you will kill a lot more people.ump/scar/416 auto aim accurately.game over.
I as probably playing fps before you knew what a pc was ;)
I'll rephrase my statement - you aren't hip firing in this game from 100+ metres away
Lol - sometimes this game brings some funny surprises. I mistakenly clicked on Squads on my own instead of solo. Got 3 random french dudes. quiet start but then we got into a large battle and all three went down and I had to leg it for the zone. 28 left and on my own. Props to them - they stayed around spotting for me.
End game below......apologies for a couple of gentle french swearies but nothing too bad!
Great finish!
I need to try the Mini 14 again, I've not used it since 1.0 and the game has run smoother, but it needs the extended mag.
Got this game couple days ago played a few games...still to get any kills though.. my aim just seems to be so bad.. not sure whats wrong as I was a pr0 in CS 1.6 :p
