Intel bug incoming? Meltdown and Spectre exploits
We have a bunch of vms including database servers in test environments where security is no issue but performance is.
Unless the testing is purely functional, it should really be run in an environment that's representative of production - i.e. with the patch enabled. It'll be no good proving performance in test only for it to be slower when released to live.
I realise I've made a lot of assumptions above :)
Plus if you use production data in the test environment then security is just as important as in production. I imagine in testing you'd want to try and emulate production as closely as possible to minimise any surprises that might happen when moving from testing to production.
No point running tests on a test database with 100MB of data if your production database is several GBs.
The answer to that is no (and this doesn't relate to the ME vulnerabilities discovered last year), the MS patch isn't enough to fully mitigate the issues.
More information can be found here for servers - https://support.microsoft.com/en-us...-to-protect-against-the-speculative-execution
and here for the desktop OS - https://support.microsoft.com/en-us...ive-execution-side-channel-vulnerabilities-in
Main things to note, you need an AV that is adding the reg-key for the patch to be installed. If you're on a Windows server OS then you will also need to add reg-keys AFTER the patch install to enable the fix.
There is also a powershell module that you can install to verify the status of the machine.
Thanks for the detailed response.
It's not looking good for folks like me on older hardware. My MSI mobo bought in April 2012 stopped receiving BIOS updates in November of the following year so I also don't have the Intel ME fix either.
Kaspersky is apparently good to go for the MS patch but without the firmware updates this is rather a problem.
What I've done so far is enable ad blocking as I see the browser as the biggest attack vector along with obvious precautions on other software being installed such as dev reputation and source of files.
Also, this is the link for the Chrome suggestion to isolate sites into their own processes as touched on in that video.
https://support.google.com/chrome/answer/7623121?hl=en-GB
Any idea if the fixed CPU microcode can be sourced directly from Intel without it needing to be baked into the mobo BIOS and it being applied like a driver update?
Because you need a BIOS update / CPU microcode patch to fix the security issues. If your motherboard maker hasn't released an update in the last 24 hours then wait until they do and update as soon as possible. These security issues can't just be fixed by an operating system patch, you need a BIOS update / CPU microcode fix.
So is this fixed at the OS level, ie a Windows Update, my laptop manufacturer just pointed me towards https://meltdownattack.com
There are 2 separate vulnerabilities (Meltdown and Spectre), however there are 2 different exploits discovered against Spectre so far.
Meltdown: affects Intel CPUs and one Arm core – the yet-to-ship Cortex-A75 - this can be mitigated via OS updates (of which MS have released updates, and Linux updates are available)
Spectre variant 2: affects Intel and Arm cores. OS Kernels and hypervisors (i.e. VMs) need patching. Skylake (and later) CPUs need a microcode update (so potentially a BIOS update) to help mitigate this.
Spectre variant 1: affects both Intel and AMD CPUs, and certain ARM cores. It is difficult to exploit as relies on timing based attacks, but some measures are being taking by Software developers (e.g. Browsers already have a patch to make timers less accurate)
Paraphrased somewhat from:
http://www.theregister.co.uk/2018/01/05/spectre_flaws_explained/
Edit:
Misread Skylake microcode clause
For most home users, why the panic this is just a threat no certain attack.
How do you know there's no attack?
The point is there's no record of the attacks if/when they happen - so nobody can know.
Now everyone knows about the attacks they're very likely, so quick fixes are important.
I still think there will have been lots of attacks historically, but obvs can't prove it.
Spectre variant 2: affects Intel and Arm cores. Pre-Skylake CPUs need a microcode update (so potentially a BIOS update) to help mitigate this. OS Kernels and hypervisors (i.e. VMs) also need patching.
Thanks.
So my i5-7200U what will that require.
Well my board still gets BIOS updates (Asus x99-A), last one was 4th December, and ive only updated the BIOS once, when i got it, with the 1004 BIOS for the Xonar compatability, not looking forward to having to do another.
Can see many a machine being bricked here.
no bios update for my gigabyte z370 yet. Glad i am not overclocking things anymore or this would be no doubt more of a pain in the bum.
So, how exactly is this exploited? For example; If you're running a server and not installing any new software or browsing any websites, how can an attacker possibly exploit the meltdown/spectre vulns?
On a standalone server with no Virtualisation, then risk is low - you would need some other exploit or user intervention to get into a situation where this would be exploitable.
However on VM's and similar this potentially allows data to "leak" between VMs - hence why Cloud providers are understandably worried.
For home users, the risk is that information can potentially be "leaked" between sandboxed apps (e.g. browser tabs), e.g. a maliciously coded advert etc in one tab, could potentially read information from a 2nd tab.
Although exploits are difficult to produce and not necessarily in the wild - now the vulnerability is public knowledge, it's likely that more evolved exploits will come.
So I assume other devices like routers, switches and hardware firewalls are not affected due to an attacker not being able to run code on them devices?
I think you're basically safe in that scenario.
Yeah, my thoughts exactly, thanks for confirming. I've not had chance to really read up for myself.
