Intel bug incoming? Meltdown and Spectre exploits
You need to check that. That is how it works, but a lot of those won't let you load settings in from a different version of the BIOS. ie it's fine for/loading saving different settings on the same BIOS, but won't help you if you update the BIOS and expect to load the old settings into the new BIOS.
Ah, damn. That sucks. I'll see what I need to do. Failing that it might be time to take a photo of every BIOS screen and then just copy the settings by hand.
No comment from ASUS yet .. I usually avoid BIOS updates like the plague but it looks like I'm going to have to do it this time.
For people that want to catch up on this quickly, I'd recommend looking at the slides below:
https://www.renditioninfosec.com/files/Rendition_Infosec_Meltdown_and_Spectre.pdf
and the recorded webinar can be found here:
Thanks this was very detailed, however it didn't confirm whether the pending Windows patch would be enough if you haven't also updated your BIOS which I assume is to rebake in the Intel Management Engine firmware with the latest fixed version.
OK so apparently my motherboard has an Overclocking profile thing in the BIOS where you can save your BIOS settings to a file on a USB drive. Am I right in thinking that to update the BIOS all I need to do is save the settings to USB, update the BIOS and then load the settings back again? I really hope the update process is easy.
If your BIOS allows you to take screenshots I would do that of each page of your BIOS settings as not all updated BIOS's allow you to use the settings from a previous BIOS version.
The answer to that is no (and this doesn't relate to the ME vulnerabilities discovered last year), the MS patch isn't enough to fully mitigate the issues.
More information can be found here for servers - https://support.microsoft.com/en-us...-to-protect-against-the-speculative-execution
and here for the desktop OS - https://support.microsoft.com/en-us...ive-execution-side-channel-vulnerabilities-in
Warning
Customers who only install the Windows January 2018 security updates will not receive the benefit of all known protections against the vulnerabilities. In addition to installing the January security updates, a processor microcode, or firmware, update is required. This should be available through your device manufacturer.
Note Surface customers will receive a microcode update via Windows update.
Main things to note, you need an AV that is adding the reg-key for the patch to be installed. If you're on a Windows server OS then you will also need to add reg-keys AFTER the patch install to enable the fix.
There is also a powershell module that you can install to verify the status of the machine.
Unfortunately it sounds like I'll have to do that which will be a pain. Thanks for the info.
Are you running the latest version?
Here are the KBs for different versions:
1709 - https://support.microsoft.com/kb/4056892
1703 - https://support.microsoft.com/kb/4056891
1607 - https://support.microsoft.com/kb/4056890
1511 - https://support.microsoft.com/kb/4056888
Are you running any of these AV applications:
Vendor
Product
Sets registry key
Supported
Sophos
Anti-Virus and Central
N
N
Symantec
Endpoint Protection
N
N
Trend Micro
N
N
Webroot
N
Y
Cyren
F-PROT
N
EMSI
Anti-Malware
N
N
Intel
McAfee
Carbon Black
N
N
edit: Sorry, formatting lost in paste.
Yeah latest window 10 only recently fresh install from the creator update. Anti virus software I using is avast.
Can anyone confirm that disabling the windows update service stops the patches?
We have a bunch of vms including database servers in test environments where security is no issue but performance is.
Do not do this, if it's a Windows Server OS then the patch will apply BUT it will not be enabled. Please read the MS articles.
You have to manually enable the patch (you have to add 2 reg-keys), which will then potentially cause/give a performance impact.
EDIT: I would seriously recommend you also read this article - https://support.microsoft.com/en-us/help/4073225/guidance-for-sql-server
Sorry. Why are people updating BIOS now?
Because you need a BIOS update / CPU microcode patch to fix the security issues. If your motherboard maker hasn't released an update in the last 24 hours then wait until they do and update as soon as possible. These security issues can't just be fixed by an operating system patch, you need a BIOS update / CPU microcode fix.
VMware 5.5 or 6? I'm not seeing any patch for 5.5 as of yet.
Those and some 5.1 which doesn't look to be supported. It seems that firmware upgrades are not needed to cover off Meltdown but does the other exploits so it isn't quite as urgent to do those over the software updates.
Doesn't look like VMWare Workstation Pro 14.0 has a patch out for it yet. I'll keep an eye on things and see what happens over the coming days.
TBH i cant see the majority of pcs getting a bios fix Unless your on a reasonably recent chipset
