Intrigued by the afterburner comments... I’ve always found precision annoying and buggy when it comes to stuff like starting with the OS in the right profiles but recently moved to MSI and seems better. But now I might have to go back
You have cold air blowing on your V Kaap?
Also, I'm not sure what this new unlocked core voltage % from 0-100 in MSI afterburner is suppose to do.
There's something fishy there. If one card performs the same at 16x and 8x then that means if two cards perform differently at 16x and 8x it's a board issue or something else skewing the data (I.E an issue with the benchmark?) not a difference between 16x and 8x.
Because it's an obvious error in the test, something they should have caught before making the video.Who cares? Normal people aren't going to experience this bottleneck so why give a ****!!!![]()
Out of curiosity as I may have ordered something from the Nvidia store, What is the processing and actual waiting time for UK customers please peeps ?
About 2 or 3 working days.![]()
Well at least someone's actually going to be using it for what it's designed for...beastly card for ML, worth every penny.
