- 14 Aug 2017
I've been playing with the soft power tables and this is my water cooled air card mining cryptonight (hash is 1650-2000H/s). The same tweaks apparently work well for Ethereum too and it's certainly a lot cooler - and uses less watts - than the water block alone. I was trying to work out what's causing the power spikes on Vega and wondered if it was workload related. Doesn't appear to be....
You can check out the guide I used here: https://www.reddit.com/r/MoneroMining/comments/74hjqn/monero_and_vega_the_definitive_guide/
HWINFO Screen here: https://ibb.co/iUJr6w
I'm actually quite new to all this, I just used nicehash before when the going was good and since then it had become 2$ a day on my 1080 so I stopped, so this friend of mine set this for me up and he said it will be more profitable than Etherium. My only surface level knowledge would say Cryptonight is another algorithm? Would it give me more than UBIQ?
