- 6 Jan 2013
- Rollergirl
Still doesn't explain how you are able to go below ambient.. The only thing i see is 2 tubes leaving the back of the case.. are they going somewhere special?? i'm curious.
Crammed a fair bit into this mATX build with a little help from an external radiator in the garage.
ahhh.. that explains a lot.. thanks for sharing.Sorry, I was assuming there.
My external garage is adjacent my office, and I have the PC in the office and the pump/Res/Rads in the garage... All linked via the tubes you see leaving the back of the case.
3440 x 1440 and at 120hz
Don’t you get any condensation from that.?Sorry, I was assuming there.
Which monitor is that.?
WOW didn’t know there were any 3440x1440@120hz monitors. Is it still using DP 1.2 ? because that’s like 20% more bandwidth than 4K@60hz.Acer predator z35p
