1080ti idle temps 55c, wot are ur idle temps??
Still doesn't explain how you are able to go below ambient.. The only thing i see is 2 tubes leaving the back of the case.. are they going somewhere special?? i'm curious.
Crammed a fair bit into this mATX build with a little help from an external radiator in the garage.
Very effective, especially in the winter months. A friend of mine did a similar build - made easy as his room was directly above the garage.
Sorry, I was assuming there.
My external garage is adjacent my office, and I have the PC in the office and the pump/Res/Rads in the garage... All linked via the tubes you see leaving the back of the case.
ahhh.. that explains a lot.. thanks for sharing.
Don’t you get any condensation from that.?
