I'm so tempted to get a 8700k and Asus Hero X Can currently get both together for £544.95 and Asus are doing a £60 cashback promotion so £484.95 for bundle.
Asus Strix 1080ti. Wanted to upgrade to a m.2 ssd and ddr4 so might as well get the best especially with the cashback offer.
Thats complete and utter nonsense.
I'm running the cheapest ram i could get a hold of (16GB Corsair LPX 3000Mhz) £180, and the cheapest B350 motherboard i could get a hold of, ASRock AB350 Pro 4 (£75) i set the XMP profile and selected 3000Mhz, it took 10 seconds and has been running 100% stable since i set it like that.
The Ram thing was an issue very early on, with it being a brand new architecture, Ryzen had exactly the same problems Intel had with X99 which was their first adventure with DDR4. everyone seems to have forgotten about Intel nightmares with DDR4.
At this point all you do is update the BIOS on your new board, if its an old one, set your ram to its rated speed and away you go, that's it.
Unfortunately it is still not that simple for all Hynix ram on all boards. It is a better but quality Bdie on Ryzen runs faster at lower latency than Hynix. To give an example my 2x 8gb Corsair lpx 3200 c16 ran at most 3066c16 not being completely stable, my current 8 pack ram when 2 x 8gb ran fine at 3333c14 or 3466c15. The 8 pack will boot at 3600c15 but crashes eventually under any real load.
i have the non 8pack Team Group Dark Pro 3200 are they samsung?
That's Asus, you need to direct your frustrations at Asus as at this point ram compatibility is entirely down to them, AMD have done their part and others don't have the problems you are experiencing, the longer people keep blaming AMD for it the less likely its going to get fixed because people like Asus are happy to sit back and let AMD take the blame instead of investing in fixing their own broken boards.
BTW how do you know what Memory IC's you have?
It’s not just asus and affects other motherboard manufacturers. There is a utility you can download that provides great detail on your ram. Currently ASRock and asus have the best performing am4 boards with the ch6 and Taichi. Things have improved since release but Bdie simply performs better on Ryzen than Hynix, which is why the 8 pack 3200 is faster and lower latency.
Yes, The 8700K is the best Gaming CPU right now and you will need it to get the most out of that GPU.![]()
I'd say the 4c 8t X299 chips are the fastest gaming CPU's.
Coffelake is a b0rked CPU. Probably worth keeping that in mind.
The 7700K? i disagree, 4 cores 8 threads has had its day, the IPC and clock speeds of the 8700K are the same but with 2 extra cores, win win, pricey tho.
For anyone interested in Ryzen overclocking, especially Ram, there is no better guide than this one from AMD's Robert Hallock, he's a top guy and of course more than anyone he knows what he is talking about when is comes to Ryzen, if you haven't seen this already its a must watch.
yeah im hynixHit and miss, the 8pack ones are guaranteed to be Samsung, the standard Team Group Dark Pro have been found to have Samsung but its not guaranteed.
The only way you can be sure is it you use whatever application DarkHorizon472 used to check his, or another less reliable way is to look at the rated timings, if they are 14-14-14 then they are almost certainly Samsung B-Die because only Samsung B-Die are capable of running CL14 at 3200Mhz + on any system, including Intel, not getting Ram to run at CL14 3200Mhz on anything other than Samsung B-Die is not a Ryzen thing, its a RAM thing![]()
How would they be faster than an i5-8600K?The 7740x and 7760x I think.
Yes Ryzen refresh is just around the corner but they are not going to magically start beating Intel in games where they are currently behind. The i5-8600K and i7-8700K will be the game kings regardless of what happens, but AMD's offerings will almost certainly be better bang for buck.
