Surely fitting a letterbox cage would make it easier for somebody to steal your post?
depends on the type, some drop down to floor level but stay in the cage
order them a letterbox cage, fit it, say it's always been there and she's just making it up.
So the answer is to lie and create a false story, potentially committing perjury in court? That's not the best advice...
Dog thought it was a burglar trying to reach for the car keys. Case closed.
it's not a lie... the letterbox cage has always been there!
you forgot to replace letterbox with glory hole, unless 'letterbox' is some slangNot buying it. I replaced the mystery woman with the OP and then substituted the roving hand for his penis. Suddenly this all makes a lot more sense and is in line with what is expect from a denizen of GD.
you forgot to replace letterbox with glory hole.
Which is fair, up until it's established that the dog's reaction is to bite. At that point it goes against the defendant.Did the dog react to something which it probably has never seen before, and probably will never see again? Yes.
"may" being the operative word. What she was doing wasn't unreasonable really.
See, you'd never find a cat doing this...cats > mutts.
Hi, not really after legal advice, just people's experience. Basically a friend is being sued, as a lady posted mail thru the wrong door and tried to get it back by sticking her hand through the letter box and his dog nipped her finger , any idea where he stands?
