PLAYERUNKNOWN'S BATTLEGROUNDS - Thread
If you right click ammo off the ground it will fill your inventory and leave behind what you can't carry, but only right click and it has to be off the ground - it doesn't work off player bodies or with drag/drop.
I need to try this again then - I think every time I've right clicked it's asked for me to specify the amount. Drag and drop with a left click and it goes in, but will get me to specify the amount if my inventory isn't capacious enough for the full stack.
It definitely works the way I've said it, been doing it since the start. If you right click off someone's body and it goes over capacity it will bring up the box. Right click off the ground and it'll just fill up your bag.
Turn that off? How do you mean? Auto-pickup the max amount for your inventory?
It has always been the case that if you don't have enough space in your inventory for the complete stack of ammo, it'll prompt you to select the quantity you want to take. I've never had it auto-pickup the right amount to fill the inventory.
Originally, and I mean as of a few days ago, you used to be able to just drag over from the left (body or floor), into your bag very quickly. It would automatically leave ammo behind which didn't fit. It appears, it still works this way using standard F to pickup (e.g. not using TAB method).
The change, now means that using drag and drop, an amount box will display if youre full (defaulted to 1 piece), which is a huge change and considerably slower to loot (unless I'm missing something here).
I'll give it another go later :)
I've been playing for about 3 months and I don't think I've EVER had it pop up a box asking how many I want if the ammo doesn't fit. It simply leaves it behind. I don't think I've ever dragged and dropped though. Surely it's quickest to right click ammo?
How is that an aimbot lol. The first guy was not even looking in his direction and I'd hardly call that snapping. Salty accusers are just as bad as the real cheats.
Press right click control.
EDIT: Nevermind, I misread your post.
My best moments today playing with Bishie, Biscuit and Hawkeye. Watching the replay, I was very lucky, I had a 3 man squad in the next building who if they know I was there, could had rushed me, but since they didn't know, they decided to rush the guy who was shooting!
My POV: https://streamable.com/dp69l
Enemy view: https://streamable.com/ejckj
I has potato PC, so it's not pretty. :p
Watch from 8.30 if this is not an aimbot I will eat my cat.
Dodgy as hell, crosshair instantly snapped to both of their heads. Don't trust him one bit.
You guys :D :D :D
Have you never watched a professional PC fps player? That Shroud double kill is BASIC flick aiming. Go watch literally any Counter Strike highlights from any player on a top team and you will see much more impressive flick shots than that relatively unimpressive (for pro standards) double kill.
I'm guessing Iron Warrior and scrivz are coming from console and this is your 1st PC fps?
Here's one for you:
KennyS highlights. One of the best CS:GO awpers.
