- 21 Oct 2012
Yea one of thoseIt's per clock/cycle rather than core. It's a measure of how many calculations can be completed for every cycle/clock of the processor (since Hz is a measurement of cycles)
He should wait for the i7 9790k. That thing will do 6.2GHz out of the box.
Is there really a cpu called the I7 9890k coming out soon?Ah. The guy from the Alienware thread.
Honestly, right now, you'd be WAY better off getting one of 8Packs delidded 8700k chips that are guaranteed to hit 5.0GHz than go out and buy a Threadripper for gaming.
Everyone has a budget. Whether it's £600 or £3000+ there is always a better way to spend that amount of money. My advice is to concentrate on the graphics card. Best on the market right now is GTX 1080Ti but consider that in spring we will be expecting the next gen graphics cards so it might be wise to put a placeholder card in until the new ones launch.
Where gaming is concerned, if you are looking at spending £600 on a CPU and £300 on a GPU or £300 on a CPU and £600 on a GPU then the most expensive GPU will grant FAR better gaming experience than the CPU.
I'll look into that. I also need the best chassis
whens that coming out?
It isn't.
It was a joke?
Afraid so.
Ok good to know.Not for a while yet. And when it does the extra 2 cores are unlikely to have a big effect in games.
This, its idiotic to put everything into the CPU when the CPU makes little difference, especially if you're not getting an £800 GPU, the best CPU will make no difference from one costing half as much.
A GTX 1070 with a Ryzen 1600 has much higher gaming performance than a GTX 1060 with an 8700K.
As long as the CPU is actually a slow one the only thing that matters is the GPU.
Can't offer a massive amount of help but the reason this is mostly said is because a high end air cooler is usually better than most of the AIOs on the market. Maybe not in outright performance but better when considering noise/performance/costCooler
(looking to buy the best thing, I hear air is better than water, is this true?)
If you're after the best cooling, then a custom water loop is the way to go. However a high end air cooler will perform more than adequately.
The 1950X has 16 cores 32 threads, its massive overkill and the 8700K would be better for gaming because it has higher clock rates, the 1950X is for productivity workloads.
Right now the 8700K is the best CPU to pair with a 1080TI, anything less than that i would recommend a Ryzen 1700 or a 1600, spend the difference on an M.2 driver or something.
However, Ryzen 2 is out in a few weeks, i think you should wait until then.
so you're saying the Ryzen 2 is going to be better than the I7 8700k? And if so, completely in every way?
No, we don't yet know how good, or bad its going to be, but if its good an 8 core 16 thread Ryzen 2 would be better future proofing than a 6 core 12 thread 8700K.
I'm saying wait and see.
Ok, but what about the motherboard? is the one I suggested the best one?
