Need expert advice on building a rig better than the Alienware area 51 threadripper edition.
I'll look into that. I also need the best chassis
He should wait for the i7 9790k. That thing will do 6.2GHz out of the box.
whens that coming out?
Ah. The guy from the Alienware thread.
Honestly, right now, you'd be WAY better off getting one of 8Packs delidded 8700k chips that are guaranteed to hit 5.0GHz than go out and buy a Threadripper for gaming.
Everyone has a budget. Whether it's £600 or £3000+ there is always a better way to spend that amount of money. My advice is to concentrate on the graphics card. Best on the market right now is GTX 1080Ti but consider that in spring we will be expecting the next gen graphics cards so it might be wise to put a placeholder card in until the new ones launch.
Where gaming is concerned, if you are looking at spending £600 on a CPU and £300 on a GPU or £300 on a CPU and £600 on a GPU then the most expensive GPU will grant FAR better gaming experience than the CPU.
Is there really a cpu called the I7 9890k coming out soon?
This is what I got so far in terms of parts data...
Gaming desktop rig parts
Motherboards
Rog Strix Z370 series <----is there anything better than this for?
GPU
(minimum will be a 1080 ti) SLI I wanted before but i hear its not getting much support in the future so a lot of controversy there and I hear theres a new card coming winter?
Hard drive
512GB M.2 PCIe SSD (Boot) + 2TB 7200RPM SATA 6Gb/s (Storage)
Monitor
(ive done little to no research here)
Memory
32GB Quad Channel DDR4 at 2666MHz
32GB Dual Channel HyperX™ DDR4 XMP at 2933MHz
Cooler
(looking to buy the best thing, I hear air is better than water, is this true?)
Power supply
(C
entauri 1500W High Voltage Chassis R6 or 850W) < Im hearing some controversy with watts)
Keyboard
Corsair Strafe RGB, MX-RGB
Mouse
(least of my concerns at the moment.)
Desktop case
(really want the best/ideal case for this rig)
Processor
AMD Ryzen™ Threadripper 1950X (16-Core, 40MB Cache, Overclocked up to 3.6GHz on all cores)
Intel Core i7-8700K
So you see, theres a lot I have missing, previous choices i'm looking to replace. If there is anything conflicting please let me know as I'm new to this.
Need the best cooler for this rig setup
Motherboards
GPU
Hard drive
Monitor
Memory
Cooler
Power supply
(C
Keyboard
Mouse
Desktop case
Processor
Intel Core i7-8700K
This, its idiotic to put everything into the CPU when the CPU makes little difference, especially if you're not getting an £800 GPU, the best CPU will make no difference from one costing half as much.
A GTX 1070 with a Ryzen 1600 has much higher gaming performance than a GTX 1060 with an 8700K.
As long as the CPU is actually a slow one the only thing that matters is the GPU.
Im preping for future too, heres the data i got so far.
Motherboards
GPU
Hard drive
Monitor
Memory
Cooler
Power supply
(C
Keyboard
Mouse
Desktop case
Processor
Intel Core i7-8700K
Cooler
Can't offer a massive amount of help but the reason this is mostly said is because a high end air cooler is usually better than most of the AIOs on the market. Maybe not in outright performance but better when considering noise/performance/cost
If you're after the best cooling, then a custom water loop is the way to go. However a high end air cooler will perform more than adequately.
Im after the best cooling so tell me the name of this thing so i can look it up.
The 1950X has 16 cores 32 threads, its massive overkill and the 8700K would be better for gaming because it has higher clock rates, the 1950X is for productivity workloads.
Right now the 8700K is the best CPU to pair with a 1080TI, anything less than that i would recommend a Ryzen 1700 or a 1600, spend the difference on an M.2 drive or something.
However, Ryzen 2 is out in a few weeks, i think you should wait until then.
Right now the 8700K is the best CPU to pair with a 1080TI, anything less than that i would recommend a Ryzen 1700 or a 1600, spend the difference on an M.2 driver or something.
so you're saying the Ryzen 2 is going to be better than the I7 8700k? And if so, completely in every way?
No, we don't yet know how good, or bad its going to be, but if its good an 8 core 16 thread Ryzen 2 would be better future proofing than a 6 core 12 thread 8700K.
I'm saying wait and see.
Ok, but what about the motherboard? is the one I suggested the best one?
If you are waiting.... then you also have to wait on the motherboard given that Ryzen and Intel don't use the same boards.
If you're not going to wait the ROG Strix Z370 is a good board.
