I would like to share my experience with the Aorus X5 so that it can help anyone on the fence. I bought the X3 and the build quality was not impressive and had issues with 3 units until I gave up on that model and bought the X5 instead. I have had the X5 for a month now and I can confirm that I had no issue with the machine. Everything works butter smooth and the thing is incredibly powerful. I even abandoned my desktop which is downstairs as it is freezing down there.
At the time of writing this there is an incredible deal on OCUK for the exact model I got. (even cheaper than what I paid for
). They are even throwing in a backpack!!!!
I would like to thank @MiSJAH for sharing with me his experience. If I have to give it a con it would be the battery life (I know this is not a machine for maximum battery life) and heat (It can get a bit warm on the left side) but it doesnt overheat in anyway. The 4K panel is beautiful and Gsync makes everything smooth. Keyboard will need to get used to but once you do it is a joy to type. The metal finish feels super premium and the laptop is whisper quiet. You can control the fans from the Aorus Control Center (something some manufacturers still struggle to implement). I did not get a backpack as I did not buy from OCUK and bought it back in Jan T_T. Just be aware that the laptop is on the BIG side for an 15 inch so it will NOT FIT on some bags/backpacks. Weight is portable and quite amazing compared to the performance you are getting inside. I can happily say that I would recommend Aorus to anyone.
PS: I had a gigabyte motherboard which was still working after 4 years (It went through 3 PSU that I killed by hooking it up to a power hungry GPU) and it only stopped when I was repasting and accidentally broke a transistor. This board was mid range and gave me a great impression of gigabyte. Oh and I am still rocking my two gtx980 ti's by gigabyte.
). They are even throwing in a backpack!!!!I would like to thank @MiSJAH for sharing with me his experience. If I have to give it a con it would be the battery life (I know this is not a machine for maximum battery life) and heat (It can get a bit warm on the left side) but it doesnt overheat in anyway. The 4K panel is beautiful and Gsync makes everything smooth. Keyboard will need to get used to but once you do it is a joy to type. The metal finish feels super premium and the laptop is whisper quiet. You can control the fans from the Aorus Control Center (something some manufacturers still struggle to implement). I did not get a backpack as I did not buy from OCUK and bought it back in Jan T_T. Just be aware that the laptop is on the BIG side for an 15 inch so it will NOT FIT on some bags/backpacks. Weight is portable and quite amazing compared to the performance you are getting inside. I can happily say that I would recommend Aorus to anyone.
