It's a 3000 mAh battery.
Thanks. Back to the drawing board
P smart is a Vodafone only thing I thinkWhy has Huawei released two identical smartphones with the P Smart and Honor 9 lite?
Keep us updated on battery life. That's the main issue for me!
and can be had for only $158 + $10 international shipping - crazy![]()
How are you finding this? I need a secondary phone running Android and seems to fit the bill.
Also where is best to order? You seemed to get yours fast and have seen some long lead times..
What's the ROM like on the VKworld S8? It say's Android 7.0 but it is stock or a knock-off Chinese one?
Doesn't look like it supports BT network either, unless its just been missed off the specs. Could be an ideal option for someone I know if BT network is indeed supported.
Then there is the oukitel k10000 with a 10000mah battery.
Well for me I needed an android phone as a secondary and didn't want to spend much more than 150, looks like it does the job and is asthetically pleasing compared to the others on offer .
The LG X Fast seems good specs for under a £100 if you don't mind not having the latest version of Android.
https://www.eglobalcentral.co.uk/lg-x-fast-x-mach-lgk600y-x5-32gb-3gb-ram-dual-sim-white.html
snip
...I assume no newer ROM available OTA when you go in to the settings?
Over the air.
