Asus and ASRock 370's basically give me multi gpu where the 350's don't ? plus a few other small differences.
Definitely want mini. Is it going to make any difference which MB I pick as I'm using two monitors ?
Just found this,
https://uk.hardware.info/comparisontable/products/403179-402611-417127
Can't afford it all in one go but I've dropped the memory to save a bit of money, would probably go for the 32gb in the end, the 450W power supply should be plenty ?
My basket at Overclockers UK:
- 1 x NZXT Aer P & F Fans / Kraken AIO Cooler Red Fan Trim 120mm x 2= £4.49
- 1 x NZXT Kraken X52 AIO Water Cooling Unit - 240mm= £129.95
- 1 x be quiet! Pure Power 10 400W CM 80 Plus Silver Modular Power Supply= £64.99
- 1 x Team Group Night Hawk LED 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Red Light (THRD4= £179.99
- 1 x NZXT H200i Mini-ITX Case - Red= £129.95
- 1 x Asrock Fatal1ty AB350 Gaming-ITX/ac AMD B350 (Socket AM4) DDR4 Mini-ITX Motherboard= £104.99
- 1 x AMD Ryzen 7 Eight Core 1800X 4.00GHz (Socket AM4) Processor - Retail= £289.99
Something like this ?
- 1 x In-Win 301 Micro-ATX Gaming Case - Black= £76.99
- 1 x AMD Ryzen 7 Eight Core 1700 3.70GHz (Socket AM4) Processor - Retail= £248.99
- 1 x Gigabyte GA-AB350M-Gaming 3 AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard= £72.95
- 1 x Cooler Master Hyper 212 Evo CPU Cooler= £26.99
- 1 x Team Group Night Hawk LED 32GB (2x16GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Red Light (THRD= £299.99
- 1 x be quiet! Pure Power 10 500W CM 80 Plus Silver Modular Power Supply= £78.95
Thanks. I can leave the Cooler Master for now and just use the the stock fan with the 1700 as I'll want to go with the NXZT fan and cooler eventually.
Is it actually worth buyer the X version ?
Would the 450W bequiet be ok ? It’s reduced at the moment.
