Always keep a backup fund![]()
My back up fund is enough to run a Volvo, not an Aston![]()
Is the guy that used to own the other one on here still about
Forgot his user
I don't see why it is that expensive. The cars are over ten years old. There is a plethora of online knowledge for fixes to problems. Most of the electronics will be ford/Volvo. As long as the V12 doesn't throw a wobbly he will be fine. Long gone are the days of 355's needing the engine taking out for a cambelt.
Wasn't it pepsilol? He's considerably richer than yow
Is that a joke or a dig I can’t work it out. Do you know my car history?![]()
No no. Pepsilol just basically thinks everyone else is a pauper.
Ah I thought that’s what you meant was just checking
Tbh two years ago when I nearly bought a DB9 for considerably more money I may add he was really helpful
which was reading the oil was fully topped up where as the engine should have actually had more oil in.Ah that's because he knew you weren't a pauper. You're allowed in the club!
I did have a look online for V12 realiability as much as I could, I found next to no known issues with the engine and that generally it’s pretty strong.
There’s was an issue with oil starvation on early DB9’s and the issue was....the dipstick was too longwhich was reading the oil was fully topped up where as the engine should have actually had more oil in.
Aston rectified this with a recall by releasing / fitting a new short dipstick to allow more oil to be added.
The issue normally happened over harsh cornering etc.
https://aston1936.files.wordpress.c...5v2-shorter-dipstick-for-db9-v12-vehicles.pdf
Paging @pepsilol![]()
Mitsubishi L200 (Triton) base model with;
- Sportsbar
So you can have a beer and watch the footie as you drive along? Does it go in the back?![]()
That ram doesn’t look pedestrian friendly
Straya! To stop the 'roos from coming through ya windscreen when you're in the outback mate.
