Good old KSP - more struts!!![]()
Struts are CPU hogs though :< (So I use the joint reinforcement mod instead
The Chief Editor of CanardPC Hardware now says on twitter that they did test the 2700X CPU on both X370 and X470 boards, but ended up using the A320 board for a stock review.
He also mentions that with auto overclocking/boosts enabled on the X470 board, you can see a 5-8% speed gain over stock settings.
Source : https://twitter.com/d0cTB/status/979428269329133568
About the famous Zen@5G that was hidden at the time and now used by fanboys to shitpost, It was not part of the preview. BTW, I probably know what happened. A feature planned for SMR seems to have been skipped later and is now included in PNR. Guess which one?
I’m not saying that PNR will reach 5G@air, even on a single core, but it MIGHT explain why the OC behavior drastically changed on SMR between our early platform and the retail one. I’m still investing on this..
So 5 - 8% in gaming over their A320 results, that would make it 8 -11% total, the 8700K was only 18% faster, wonder what they mean by "cheats"
It will be interesting to see what clockspeeds Zen+ can reach when overclocked and with sufficiently good cooling.
The cheating CanardPC is referring to originally comes from the MCE (Multi Core Enhancement) was enabled by default on some Coffee Lake motherboards.
This caused some 8700K reviewers such as Linus and Gamersnexus to post MCE enabled (OC) 8700K benchmarks as stock settings.
MCE is a bios setting that forces the CPU to run at the highest frequency on all CPU cores simultaneously.
The bios on CanardPC's X470 motherboard had all kinds of boosts enabled by default.
I guess this was the reason they used the A320 to make sure no boosts was active for their 2700X CPU review.
@CAT-THE-FIFTH would i be right to assume that by "Cheats" CanardPC are actually talking about Precision Boost 2? "cheats" is just bad English, or perhaps they actually believe that the Precision Boost 2 behavior is some form of cheating and they used the A320 results because Precision Boost 2 is disabled or not working on that board.
What are your thoughts?
Well that is not too bad considering Ryzen only came out last year!! Intel has had years of practice with their 14NM CPUs!!Cooling on Ryzen never seemed to have that big an impact weirdly. I would not expect too much. 4.5 common o/c on all cores from top chips would be my guess right now with a few making it to 4.6/4.7. (just based on the prior chips capability)
All core boost at 4.35ghz (or whatever) is not stock behaviour. Canard PC have not called it MCE. They've simply recognised that it isn't stock behaviour, but overclocking (or "cheats").
They already know what the speed curve should look like according to AMD. The 8700K has been designed to boost all cores to 4.3ghz at stock. That is the stock speed curve.
MCE boosts the 8700K for all cores to it's single core speed @ 4.7ghz. If all 2700X cores are being set to 4.35ghz then that would be the same thing, as 4.35ghz is also the single core boost speed.
The A320 board will follow the stock speed curve.
Either way, what this tells is that nearly all 2700X chips should overclock to 4.3ghz+ much in the same way all 8700K chips overclocked to 4.7ghz+.
