- 18 May 2010
- London
snip
I have yet to see evidence that logical threads makes any significant affect in games, logical threads help when you running a cpu bound application that has gaps in the cpu wait state (Cpu is waiting for i/o or ram access), hardly any game will generate that kind of load.
So core heavy games I mentioned would benefit from say 6 cores, 8 cores, 12 cores etc. But I would expect these games to work the same on a 4c/4t chip as a 4c/8t chip assuming equal per core performance and equal cache spec. I7s e.g. have a slightly larger cache than i5's so if they do run better in a game over an i5 at equal clock speed its probably due to that. Ryzen r7's actually have more real cores than a CL i7, so on games that love cores they will outperform an i7.
I'd take 4 fast cores over more slower cores for gaming - and I own a 6c/12t cpu. If you have high enough clockspeed / IPC then lack of cores doesn't matter much because each core is churning through such a lot that it can handle more of the load that would normally be spread across more cores. In fact all else being equal (cost, temps, power drain etc) I'd take a 8ghz tri-core or 12ghz dual-core over a 4ghz hex-core because the latter will be more of a bottleneck for games not optimised for lots of cores; you effectively get the best of both worlds. But of course it isn't feasible to get properly fast cores these days so we are just seeing minor gains per core with the manufacturers scaling out the number of cores.
I had an 3.8ghz 8core 16 thread CPU and more than half of it was sat idle whilst gaming. Give me a fast 5ghz 4 or 6 core over that any day.
People used to say the same things during the e8400 vs q6600 days, raw clockspeed lost that battle in the end.
As i have said before i wont be able to understand people wanting to go for the slightly faster single core (and slightly faster gaming) cpu in the 8700 when the 2700 will be doing almost as good but completely thrashing the 6 core in other areas.
Why limit yourself in the future? I just dont get it...
Do folk not run windows full of background software? Virus and malware checkers sapping threads, browser windows open, background apps and tasks a plenty?
The few gaming fps % is going to sound really stupid if these chips end up within 5 or so % of each other. Get the more powerful CPU, its the 8 core one obviously.
I keep my cpu/motherboard platforms for about 2 years before moving on. No need for more that 6 core/12 threads as I do not use it for productivity. By the time more cores are required I will have upgraded anyway so future proofing is mute. I buy for the here and now.
2.4 GHz v 3.0 GHz and I believe the dual cores overclocked better.Didnt q6600 have comparable clockspeed to an e8400 anyway? my dual core 6420 was only about 2.x ghz anyway. Clock speeds were low in that era across the board I think.
The thing is, most people don't really believe that "fewer cores with higher MHz" is better, otherwise they'd have balked at the idea of the 6 core Coffee Lake CPUs and continued touting 4c/8t Core i3s as the ultimate gaming CPUs. They only really had that opinion when Intel maxed out at 8 threads on the mainstream platform. The real world answer is you need a mix of both, leaning a particular way for each individual game, which is why the i7-8700K is king right now (and probably will be until AMD can get their per-core performance up enough) and the R5 2600(X) will probably be the bang-for-buck solution going forward.
Fixed that for you!
But agreed,all the people shouting the most for 4C/4T and 2C/4T CPUs don't have a 4C CPU now,they all have 6C/6T,6C/12T and 8C/16T CPUs.
I had a 1090T, what a nice CPU that was......
I've been saying for a long time now that quads are not enough. Not that I'm saying an 8 core is better. There needs to be a balance, 4+ cores and a min 4.5ghz is what I'd recommend to anyone that wants a system to last a few years.
The issue,is your old Core i7 4770K with an overclock would have been OK for a bit longer. Despite people saying HT does not do anything for gaming,sites like DF showed it does help out in certain games(plus I had equal cache amount 4C/4T and 4C/8T Xeon E3 CPUs),and its no wonder when so many engines are being developed with consoles in mind now.Thats the thing - most of this is going to be constrained by consoles,and even if they have 8 cores,only 6 to 7 are probably used.
So,like I said before I would argue 6 to 12 strong threads is what I would recommend for any gaming build with a reasonable budget.
The whole concept of silly high overclocked 4C/4T and 2C/4T CPUs are an utter waste of time,as any normal gamer buying a PC now is going to keep it for 3 to 5 years looking at the dozens of PC games I have met. Also,the consoles are moving to shorter lifespans,so the next gen is probably going to be here by 2020,and probably sporting even more threads,since its most likely an AMD or Intel desktop class core with SMT in them.
Also,as shown by me previously Intel is pushing for games to be more multi-threaded since they want to sell MOAR cores now!
It was a non K that is why I swapped it.![]()
