** LIAN-LI PC-O11 DYNAMIC EDITION - A NEW ENTHUSIAST PRICE/PERFORMANCE CONTENDER ARRIVES **
20 Apr 2004
Oxford
I'm look forward to it too, my current 700D based setup is looking quite janky these days
Well my 700D has no front as the power button broke, the fan grills dremeled (crudely by me) to reduce fan noise, and a no side panel as I have a single 60mm EK 140mm rad hanging out and there is not a good place to put it unless gets fed hot air from elsewhere or feeds hot air into a area where I dont want. Ontop of the normal scrapes from 7 years of builds and 3-4 flat/house/room moves
New case new WC Gear (I pretty much only keeping my pump and GPU block)
OcUK Staff
OP
26 Nov 2014
Stoke
For those who will be putting their GPU under water, here's a nice list of EK blocks and their compatibility: -
Red = Must use a vertical GPU mount
Yellow = Need to remove the plastic cover
Rest are fully compatible. I also have a list for Bitspower if anyone wants it, and am asking for Phanteks/XSPC lists too.
30 Jul 2005
Bristol
looks like i will be sticking with my hybrid cooler then rather than going full water. Dont really want vertical GPU as i use my other pcie slots
