Is a 360 rad the most you can fit at the front or could a 420 (140x3) could fit for with a little modding
A 420mm rad won't physically fit inside the case unless the mod involves having it poke out the top. The external height of the case is only 448mm excluding feet. My 420 EK radiator is shorter than my old XSPC and even that is still 460mm+ in length.
I have built my R6 blackout edition case and is an air cooled system. One of the main reasons for getting this case is noise, I want it to be as quiet as it can be, therefore I'm looking for a little advice regarding fans and what type / make of fans to use.
I'm guessing that it would be best to replace the stock fans for something else! Would it be worth the hassle? I'm running the Asus Maximus VIII hero motherboard with an i7-6700k + MSI GeForce GTX 1070 - it's not overclocked and want the ability for the fans to automatically adjust depending on what i'm doing! In everyday usage I want it be really quiet but I understand that it will need to adjust when i'm playing a game for example!
I have left the fans as default - 2no. x 140mm at the front & 1no. x 140mm at the rear.
I was thinking of replacing these with 3no. NF-P14s redux-1200 PWM (https://noctua.at/en/products/fan) - have them all connected directly to the motherboard and use the Asus software to control. Does this sound like a plan or what do you guys think?
Cheers
