Yes steel accounts for the weight. I was wondering though, once the case is has all your components in it, just how heavy it is? Can one reasonably fit person lift it OK, or is it so heavy it is best not to try?
same here mate, just make sure you put them on a piece of wood so the carpet doesnt block the psu fan if you have it facing downThanks you all been very helpful and helped me make my mind up to buy. Most of the time the case lives under my desk; I just need to lift out sometimes for *upgrades*.
Mass damping of side panels likely makes about kilogram.Yes steel accounts for the weight. I was wondering though, once the case is has all your components in it, just how heavy it is? Can one reasonably fit person lift it OK, or is it so heavy it is best not to try?
Does anyone know if the Fractal R6's side Panel would fit onto a Fractal R5 ?
Don't think so m8, the dimensions are slightly different (the R6 is bigger all round)
Built my new system in this case yesterday, really nice case to work with, plenty of room.
One thing I don’t like though which 99% of case manufacturers do is they don’t leave enough room behind the motherboard tray for all the cables and they end up getting squashed when you put the side panel back on.
Why can’t they make it 2” thicker so the door panel doesn’t squash against the back panel.
Ahhh bummer. Is it sorted now?Got my R6 yesterday but the front panel has a dent in it, several inches long. Strangely the packing case is undamaged. Hopefully OCUK will just send me a replacement panel, I really don’t want to have to return the whole case.
Edit: got an RMA to return the whole case, oh well...
100% done with mine now, not even going to bother adding another radiator as the temps are fine as is.
