- 26 Nov 2014
- Stoke
Interesting to see the official product page says the air comes with 2 120mm fans.
From what I know, the air will cost a bit more. There will also probably be an RGB version.
@ChugNorris this still inbound for start of June ? and any left for pre-orders?
All stock incoming has been presold and should arrive next week. Also, I believe there has been an issue with the White version of the case, currently we only have 10 incoming on this shipment, I apologise in advance if this directly affects any of you. More stock is due in June (probably late June)
At least stock is starting to arrive soon but still a bummer for those who pre-ordered the white version.
Black version with riser cable ordered on 26 Apr 2018 16:09:00 yay !!!
One piece of info ive not yet been able to find out yet though is does anyone know what size fan you can mount at the back of the case just above the Lian Li Tag ?
If I can get a 120mm there, i'll probably use it to bring Air into the case, top will be a 240mm radiator with fans for exhaust.
Lets hope I have room for bottom mounted fans in my SLI setup!There isn’t a a rear fan mount and it’s been confirmed to be too thin for a 120mm. You might be able to mod it to get an 80mm one in there if you’re desperate. Air being pulled from the bottom appeared to be sufficient in the tests that GamersNexus and HardwareCanucks did though.
