No its actually 22% for Cinebench MT and 4% ST
Yes, are Anand-tech now also wrong? do we only believe what AMD say above all others when it suits us?
I Still have a Ryzen 1600 and i'm willing to do a clock for clock comparison, but not from you, that trust is gone and before you react to that i trusted Gavin87 the first time round.
Given the other results, this would go down as an outlier by any reasonable person.
Everytime you talk about Ryzen, it gets faster and faster and faster.
?3%-4% maximum, which is indeed what I was endeavouring to illustrate. Slide supplied by Steve.![]()
Single threaded its actually only just over 2% slower than coffeelake, 168 vs 174 @ 4Ghz.
I believed on Ryzen 1### it was higher than that, 7% when me and Gavin compared results.
I don't think the comparison Journey was making was Coffee to Ryzen "2", it was Ryzen "2" to Ryzen.
2933 is not stock memory speed though is on the amd..
No I mean default speed.
Themn tests are so messed up around internet if it goes for memory.No I mean default speed.
4 of us on OCN got fan on haha Thermal signal noise reduction does the trick when we ware getting error around 2000-3000% memtest adeed fan gets u 10k% pass error free
4000Mhz vs 3400Mhz memory makes almost 0 difference to the 8700K.
https://www.techpowerup.com/reviews...e_Lake_Memory_Performance_Benchmark_Analysis/
Also....
I cannot believe you posted those slides and told me to look at them, as if to say they prove me wrong.MAybe have a look at 8pack tests besfore posting crap or even better maybe check the damn thing you posted ??
I know u are tight ass but i WILL pay extra 10-15 quid for 1fps in some situations.
If we are comparing Top amd Mainstream cpu with top memory setting its only logical to compare top intel mainstream with top memory. Does not matter if its 0.0001% difference TOP option vs Top option. Especially in both cases SAME MEMORY KIT woul;d be used.
It is OVERCLOCKERS forum ot pc world/currys forum ??
