- 9 Apr 2012
Thanks for all the help all.
Any recommendations on some decent snow foam?
Autobrite magifoam
Sams active snow foam
Auto finesse avalanche
Thanks mate, any ideas on a recommended foam cannon?
Theyre all the same, personally id say support autobrite given they make an effort to show up to ocuk events etc and buy theirs with the magifoam bundle.
Autobrite snow lance is far superior to any other product. Cheap ebay lances arent the same.
Id recommend Bilt hamber snow foam or Autobrite magifoam.
I have used Auto Finesse Aqua Coat for new Mustang and wife's A6 this week. Pressure Wash, Snow Foam, 2 Bucket Wash, Rinse, Apply Aqua Coat, Rinse Off, Dry.
So far its worked well.
I have however found a couple of spots on the wifes black A6 bonnet that have suffered from the dreaded bird poo etching. Without going insane and buying DA's and wet sanding is there anything I can do to remove? I have heard about people heating with a heat gun/hairdryer to try and take it away a bit but worried about screwing the paint more.
What product would be best to clean all weather rubber floor mats?
Get some Iron-X or equivalent product for removing the “rust” spots. I’ve used Dragons Breath before and that should pull that out.
Also for most things I’m becoming a big fan of Auto Finesse products recently. May not be absolute best per product but work well and easy to shop on 1 brand. I also really like their cherry scented snow foam.
That said I’m going for a CG V7 and Sonax BSD mix for QD/LSP based on comments on detailing world.
Ive done it a few times. Pretty sure it even says so on the bottle. Usual warnings about not letting it dry etc. Do a panel at a time.
