Are cheap SSDs any good or is there a catch?
14 Jan 2011
East Yorkshire
I've been playing catch up recently as it was back in 2011 that I last built my computer so have been trying to get up to speed with regard today's kit.
Basically, I am doing a full rebuild of my system ( new mobo, cpu, HDD, ram etc) and for the HDD I'm leaning toward a 1 Tb Seagate Firecuda with around a 250 Gb SSD to house my OS.
It's amazing what you get for your money these days with regard to an SSD when compared to when I last built my computer so the question is...
Given that you can get a 250 Gb SSD for around just £50, are these drives actually any good or is there a catch? Back in 2011, such a drive of that size would have cost an arm and a leg!
I mostly want to use it from which to boot my OS so it's more a case of generally speeding things up rather than having a supercharged bit of kit. I would presume that an SSD costing over double the price of a cheap one must have something in its favour so what are the benefits for going for a more expensive SSD?
Any advice welcomed as I want to get my order for the bits placed asap.
Cheers!
Back in 2011
welcome to 2018 lol
boot my OS
i'd suggest getting an ssd that's big enough to put not only the OS, but also your most used apps on it (+50%). no point having your computer boot superquick, but everything else runs like a pig.
240gb is the bare minimum, suggest a 480gb ssd instead. ssds also like to have free space so their garbage collection algorithms can run properly - else its performance will take a massive hit. normally should run an ssd no more than 75% capacity.
performance (both sequential and random IOPS), warranty and durability.
if you're going to go cheap, then get the teamgroup L5 lite 3d nand. else, if splashing out for something better - then either the samsung or crucial
(wd can also be considered, depending on the specific drive in question)
welcome to 2018 lol
Makes sense what you're saying... however, I've just done a quick check of how my existing 1 Tb hard drive is divided up and on the 128 Gb partition which holds the OS and progs there is still over 20Gb free and over half of the remaining second partition is free which is around 480 Gb actually free.... what's taking up the rest of the disc space is mostly images so I could actually get away with 128 ssd if stretched but I would have thought a 250 Gb will more than cover my needs as I don't have lots of progs that I use regularly but having said that, there's only £30-odd difference between the 240 and 480 Teamgroup L5 lite so I might as well install the larger capacity drive. I'd have thought it's got to be faster than even the fastest of mechanical hd drives.
If I were planning a new top-end build right now I'd probably go for a premium SSD, as much for the warm-and-fuzzy feeling as for impressive benchmarks which may or may not be reflected in actual day-to-day usage. For anything else, I'd say the bargain-basement models are fine, and certainly light years ahead of spinning rust of any description.
Only you can realistically judge the amount of space you'll need - my main work laptop is a seven-year-old HP EliteBook 8560w (Sandybridge i5, 8GB DDR3), and I stuck an el cheapo (£24) 120GB Integral SSD in it a couple of years ago. It runs like a champ, although admittedly it only has Win 10 Pro, MS Office 365 and various odds and sods installed, taking it to around 50% full including user data.
yes, definitely. by an order of magnitude lol. having an ssd as the main drive is the best quality-of-life improvement you can do to a computer.
(skip to 3:40 for comparison)
It is unexplainable the difference going from HDD to SSD
I managed to pick up a 480gb crucial mx500 last month for stupid cheap, since then I've gone and bought another 1tb SSD because they are truly magical in terms of speed difference
I used to be in the camp of "if I don't know the difference I won't miss it" but my regret is I never got to experience the wonders of SSD's sooner
In terms of speed it's like going from a Bicycle to the Enterprise at warp 10
I've just looked and the Crucial MX 500 is going for only a bit more than the cheaper 480 SSD I had in mind so it's really a no-brainer... I might even end up getting a 240Gb SSD for the OS etc which would be enough and a 480gb SSD for my other stuff. A cheap external 1Tb HHD would back everything up nicely so it might be worth the extra investment for the definite speed increase!
Buy the best you can with whatever budget you have.
I just purchased a samsung 970 evo 1tb m.2 drive to replace two 500 gb ssd's.
All main programs and games will be on the evo and music, videos and photos etc will be on the two 500's.
I'm definitely an SSD convert now! Even a cheaper SSDs would half most of the task times so really it's got to be a huge improvement over a regular hard drive.
i have a cheap drive i havent used yet, its a Kingspec, but my brother has one of these and hes more tech savvy than me(quads/gtx 970 and so on) and he hasnt had any issues, only cost me £19, okay my WDG 120 was a tenner more, but its not for keeps, but just because the price is cheap doesnt mean its a cheap quality drive, its down to the branding of that drive.
As I am rebuilding/upgrading my computer I intended to put in an SSD for the OS etc and a new HDD for the other stuff but I might now go down the route of a 250Gb SSD for the OS etc and a 480Gb SSD for the general files etc.
After 7 years of constantly using this computer, although I've got many 1000s of image files stored on backup drives, on the current 1 Tb HDD, including the 128Gb partition for the OS, progs etc of which 20Gb is still free, I've still only used up a total of around 500Gb of the entire drive as most of my important image files are backed up onto external drives so actually most of the files on the onboard HDD could even be deleted and only re-loaded in as and when necessary.
I could easily get away with a 250Gb SSD for the OS etc and a 480gb SSD for other stuff which would be a much faster file handling combination than an SSD and HDD. If I found in the unlikely event that I needed more space, I could always swap out the smaller SSD and transfer it to my backup computer and fit a larger SSD in my current one.
I always try to keep my onboard file storage to a minimum and clutter free and prefer backup drives for their storage to avoid the risk of a single drive failure or corruption so it makes sense to go down the dual SSD route.
One thing is for sure, I'll certainly notice a definite speed increase over what I'm using now if I fit SSDs!:p
Time to ditch mechanical hard drives.
Pros
Speed
Heat
Silence
Power consumption
Less weight
Not prone to shock damage
would you recommend upgrading to an SSD over a SSHD?
my current laptop has an SSHD 1tb and 2empty m2 slots. I had been thinking about fitting a 1 tb m2 drive to replace the main drive or should i replace the 2.5" with a 2." SSD?
all these different SSD confuse me.
If you want fast read / write speeds then drop in an m.2 drive.
Since 2008 I've had 10 SSD's, everything from early Kingston Value drives to Samsung 840's.
Of those 10 SSD's 5 have had issues, some just lost data and a reformat fixed, others totally died without warning. However some have worked totally flawless and still in use.
That 50% issue rate is to much for me, and i'm using Western Digital RE or Black drives now. It's not just me search on this very forum and there is people with plenty of failed SSD's.
One of my drives that died was a Crucial MX100 512GB, there is an america sales site and the reviews had pages and pages of people with issues/dead drives.
I've got 3 drives, two of which I've used for over 15,000 hours and nothings gone with them. Cheaper drives are fine IMO if you get ones from decent brands, just don't go looking at chinese imports with iffy reliability.
I don't know anyone who has had an SSD die. I do however know if a lot of mechanical drives that stopped working. Some of it is luck and I usually buy a recognised brand, not necessarily the most expensive.
I got a drive thats lasted so damn long even with my comp always on 24/7
49952 Hours = 5.6984 Years
don't get how it hasn't died yet, still seems to work perfect mainly use it for steam games, put what I'm actually playing on a SSD though for load times.
I think one of my SSD will die first at this rate.
probably some crap kingstom one I have as my OS drive.
I've had about 3 drives fail at work, mostly the cheaper models. I had a 120GB WD Green SSD fail recently, WD replaced it with a 240GB model under warranty.
I've probably upgraded around 150 machines at work so the failure rate is very low overall.
