Well gearbest are utterly useless.![]()
Not defending them cause you're probably right, but think the same thing happens at FT too.
At this point, why don't you just get an Engine II, by all accounts it improves on an already great tank?
), vids/pics don't do it justice, matches up well with the resin panel Pulse 80W.Royal Mail have ****** up!
Hope you get it sorted, if the Engine II is successful, imagine they'll bring out more colours if you can hang off, there is a gold Engine on the bay UK seller 'zeroeliquids' if that's any help.Hope you get it sorted, if the Engine II is successful, imagine they'll bring out more colours if you can hang off, there is a gold Engine on the bay UK seller 'zeroeliquids' if that's any help.
Thanks tommy. Yeah I was hoping that they would bring out a gold Engine II. I found zeroeliquids, it turns out to be audaciousvapes on ebay. Hmm, yep, gold is there, but they want £36 which is about double the price of the Chinese sellers. I think I'll take my chances with Aliexpress.
edit: Just ordered from aliexpress, last gold one left from a seller, $24 which is £18. I think it'll probably take weeks to arrive so hopefully my other stuff will turn up soon.
edit 2: Messaged the seller asking him to confirm he really does have the last gold one ready for me. It's certainly greyed out now on his listing, so I'm guessing he has put it aside for me. He doesn't seem to understand English though as he didn't answer my first two messages correctly.
I can't be that confident though as one other seller on there is still showing 20 left in gold but he's just told me there are no gold left, discontinued. Might have to cancel and either wait for an OBS Engine II in gold or buy it from zeroeliquids.
Does anyone have any suggestions for a single coil squonk compatible RDA at all that can fit large coils?
Your Drop can do single coil, you not tried that?
Using a 3.5mm coilology framed staple on an Asmodus C4, imagine you'd fit 4mm in there as there is still more space to go, it's not a cloud chucker at all though it's a restrictive flavour rda.
3mm NI80 framed staple in the Recurve produces more vapour than the 3.5mm C4, it's got the same perforated airflow as the Drop, will fit a 3.5mm, don't know about 4mm-maybe fit micro coil idk, but juice well is tiny, therefore you are constantly squonking.
The Recurve has been pushed as giving out dual coil performance on a single coil though, but I think it's pushing that claim a wee bit, but it is good.
From what I understand Nic Salt is essentially freebase nicotine with Benzoic acid added to it. This lowers the overall pH which makes it less harsh on the throat. So you can have 1-2 puffs of 50mg juice instead of say 10-15 @ 3mg for the same effect.
It does mute flavour a lot though, and there's no throat hit. You create a throat hit by offsetting it with a high PG ratio (70-90%).
I wouldn't bother in all honesty. You're much better off getting a small device, and a low profile RTA (Eleaf Invoke/Serpent Mini SMM for example) and just putting in a 50/50 mix at say 12mg.
Other than being careful! What do you guys use to protect your tanks?
Oh, I didn't know you could single coil the Drop. I'll try that then and see how it goes. Thanks.
I'll look into the Asmodus C4 and the Recurve as well. Thanks for the help.
Currently running the Drop tank with tsuka demon killer coils and this is a flavour/vapor machine, but my god it drinks/spits juice a goodun.debating a change of coil as they take to long to heat up if there are other suggestions? dont care for clouds at all but decent flavour is always a winner.
, really enjoying Coilology wire at the moment, they do a Ni80 Juggernaut(26*2/36*2 AWG / 0.4*2/0.12*2mm dia. / 0.1*0.4mm flat size / 1.46ohm/ft) did try one but it was too hardcore for me, but ramp up is fast, as it's Ni80, they do it in SS too.
Looked up tsuka coils, they'd kill me, really enjoying Coilology wire at the moment, they do a Ni80 Juggernaut(26*2/36*2 AWG / 0.4*2/0.12*2mm dia. / 0.1*0.4mm flat size / 1.46ohm/ft) did try one but it was too hardcore for me, but ramp up is fast, as it's Ni80, they do it in SS too.
The Recurve is well worth a look, great little single coil rda.
Cheers all
Any of you vapers suffer from asthma and notice a decline in lung capacity after vaping?
I suffer from slight asthma and sometimes after vaping I feel like my lungs aren't drawing in enough oxygen, not had this while a smoker - am I just being ghei?
30/70VG - 8mg - 0.5ohm - 50W
